by
sklemm
1 Reply
1406
Views
| Hello, we recognized a sporadically problem with a PC when starting PTC
Integrity 10.8. Client. The ...
1 Reply
1406
Views
by
tgeiger
1175
Views
| PTC-Integrity We used change packages in the past and want to access the
data after the update, beca...
1175
Views
4085
Views
| trunk tips are not matching the member revision ???
4085
Views
10821
Views
| Hi @all, since 10.7 some reference-documents has changed from pdf-format
to chm-format. But the new ...
10821
Views
9594
Views
| How do i import sandbox in Integrity build 10.9? I know project.pj files
no longer exists in this ve...
9594
Views
1441
Views
| Hello We are using Integrity 10.8.0.8356 I noticed that in the web
interface the times are displayed...
1441
Views
by
ptc-5150641
5985
Views
| It is possible to create a relationship or link from an Integrity Item
to a Source Object?
5985
Views
2951
Views
| Hi I am struggling to get items with getItemsByCustomQuery Please find
below code, MKSService.getIte...
2951
Views
3198
Views
| Hello, I am working on a project to automate our regression tests and
publish the results under MKS ...
3198
Views
by
nborrerojr.
3965
Views
| Is there a way to determine what filters a user has on the selected
view? For example, if I already ...
3965
Views
by
pnone
1 Reply
1442
Views
| Hello Support, Can you please provide me a CLI with which I can query
all the member files locked by...
1 Reply
1442
Views
9695
Views
| Hi, i'm looking for some useful custom commands. At the moment we have
custom commands for: Copy SI ...
9695
Views
by
dbatz
1104
Views
| It's necessary to do a FMEA in almost every project in our company which
is modelling. Obviously the...
1104
Views
1856
Views
| Hello, I would like to check if a Project exists within a specific
devPath vie Java-Api (or cmd-line...
1856
Views
2195
Views
| If we use the CSV loader to import a picklist field and the value
doesn't match one of the existing ...
2195
Views
2414
Views
| When using the built-in "Print" command (View --> Print) in an item of
Workflow and Documents, then ...
2414
Views
by
ptc-6557619
1541
Views
| Hi, I know two ways of getting the content of a member without having a
valid sandbox for it (viewre...
1541
Views
by
kthierer
776
Views
| Recently I stumbled over a project.pj with unusual size regarding member
count. When opening in a te...
776
Views
1753
Views
| Hello, We have an old Copy of MKS integrity which contains some legacy
solutions. We do not actively...
1753
Views
1 Reply
1922
Views
| I need to count the relationships for some items types, like for example
the number of "Validated By...
1 Reply
1922
Views
1827
Views
| how do i check if there are any files checked in to a devpath or release
1827
Views
1 Reply
1015
Views
| Hi all, is it possible to rename the project tabs? By default they show
part of a long path to the p...
1 Reply
1015
Views
2122
Views
| Hi. I'm experimenting with the si CLI command and stumbled upon a
difference in th output of this co...
2122
Views
1876
Views
| Through trial and error I have learned that using the Condition: Field
!= Field[New Value] as a Trig...
1876
Views
by
ptc-5066142
5352
Views
| Hello, I have a requirement of querying the mks integrity, based on
certain filed and fetch the stat...
5352
Views
by
sbakki
961
Views
| Is it possible to allow to attachments more than one file simultaneously
in Integrity 10.8
961
Views
1862
Views
| Hi all, I'm currently stuck in a cleanup and refactoring task for our
server setup. I want to remove...
1862
Views
by
nkanikdare
2134
Views
| How can I fire an integrity query in java and get its output and store
it? Can I get an example code...
2134
Views
by
kschwarz-2
1 Reply
1249
Views
| We want to connect MKS2009 Server with Jenkins 2.3. Which
plugin-revision is compatible with our "ol...
1 Reply
1249
Views
2509
Views
| hi all, do you have a list of all possible values for --reportTemplate
in cli? using the viewreport ...
2509
Views
| Subject | Author |
