Can we integrate oxygenXML editor with Integrity?
Define "integrate" please.
From oxygenXML editor, we would like to chekin, checkout files, creating change packages and submitting change packages the files.
Similar to what can we do with when we integrate eclipse with PTC integrity. Like creating ChangePackages from Eclipse, after a chaage is done in any file, it gets locked automatically, so easy checki and checkout, submit the change packages from eclipse.
So, can the similar integration be possible with oxygenXML editor?
From many years ago, I remember that Integrity supported a standard for CM commands, so if your tool supported the same standard it could perform the basic functions like check-in and out, etc. (nothing as fancy as the Eclipse integration though).
Unfortunately I don't remember if/where it was documented. Maybe PTC Support could tell us?
