| I'd like to have "revision description required" for Rev 1.1 instead of "initial version" automatically inserted in the revision description of 1.1. Is this possible? | ||||
| Posted By: mlizak Posts: 72 / Registered: Feb, 2011 | |||
| Hello Becker, Unfortunately, this is definitely not possible. The default text for the initial revision description is compiled into the code. Regards, Kael | |||
If this issue is of concern to you, please contact Integrity Support, so that you can be added to the appropriate SPR.
