I downloaded Thingworx ML R51.0 at ptc.com and ran Thingworx Machine Learning on VMWare.
But I couldn't access Neuron by web browser and I saw the HTTP 404 not found error.
It seems that any neorun package isn't delplyed on tomcat server.
What Should I do?
I guess the OS missed IP address.
Could you check the ip address by "ip addr" at the shell?
If there is no IP (IPv4) address appeared, it is better to set the fixed IP address by nmtui (NetworkManager TUI).
I hope this will help you.
Hi Akira
Thank you for your comment.
I checked the IP Address and I accessed the tomcat/manager however I couldn't find Thingworx ML Application in the deployed Application List.
Tell me additional check point?
ThingWorx ML does not have Web UI but HTTP REST API only.
We should access it via something REST supported tool like chrome Postman.
