Is there an API to get "Sourcing Configuration to Colorway" from PlexPLM?
I can see it in allowed data types list with getFlexObjects API.
But when trying to access actual data with getRecordsData API systems states that there is now type as "Sourcing Configuration to Colorway". I can access to for example "Sourcing Configuration".
Hi @MW_12595009 You can use the Flex-Connect Service “getFlexLinks” in Mappingscript to get the Sourcing Configuration to Colorway.
