Since we are using a Thingworx entity with our company on an azure server. I'm not able to use the ThingWorx academic simulator. As soon as I try to simulate a thing with the ThingWorx Academic Simulator it says "Unable to connect to ThingWorx. Check your server url."
Does anybody know how to solve this problem by connecting the academic simulator to our ThingWorx entity?
I'm completely new to this IoT topic, I hope somebody can help me out!
Thank you so much
Philipp
I found 2 articles, please check if they applies
Hi @PD_9717258.
If the previous response helped you to resolve your issue, please mark it as the Accepted Solution for the benefit of others with the same problem.
Regards.
--Sharon
