I need to access name of each tag on namespace XML document.
sample:
<reading xmlns="http://cyantechnology.com/dean/v1"> <link href="https://cyan-hes-vip-master:8000/v1/readings/0b4ca37b-3600-4c6d-bb9f-320ca6db71de" method="delete" rel="delete"/> <link href="https://cyan-hes-vip-master:8000/v1/readings/0b4ca37b-3600-4c6d-bb9f-320ca6db71de" method="get" rel="reading"/> <link href="https://cyan-hes-vip-master:8000/v1/dcus/ade1a127-a301-4d1d-9d6b-2fc697dc2ecb" method="get" rel="dcu"/> <link href="https://cyan-hes-vip-master:8000/v1/meters/2f8c0a92-7427-4250-af0c-803b2f211fb9" method="get" rel="meter"/> <meter-serial-number>20004687</meter-serial-number> <meter-timestamp unit="iso8601">2018-01-16T19:22:39Z</meter-timestamp> <dcu-timestamp unit="iso8601">2018-01-16T19:22:39Z</dcu-timestamp> <rtc unit="iso8601">2018-01-17T00:51:34-00:00</rtc> <configuration_manufacturer>Elster</configuration_manufacturer> <configuration_model>ELEA16301.01</configuration_model> <configuration_serial>20004687</configuration_serial> <configuration_firmware_version>A1630.01.24</configuration_firmware_version> <configuration_manufacture unit="iso8601">2017</configuration_manufacture> <relay_missing/> <tamper> <tamper_type>ok_tampered_ongoing</tamper_type> <tamper_state>ongoing</tamper_state> </tamper> <billing_3phase> <billing_3phase_reset> <billing_3phase_reset unit="iso8601">2017-12-01T00:48:00-00:00</billing_3phase_reset> <billing_3phase_summary>true</billing_3phase_summary> <billing_3phase_cumulative_real_energy unit="kWh">167.652750</billing_3phase_cumulative_real_energy> <billing_3phase_cumulative_apparent_energy unit="kVAh">323.021500</billing_3phase_cumulative_apparent_energy> <billing_3phase_cumulative_reactive_lag_energy unit="kVArh">273.756250</billing_3phase_cumulative_reactive_lag_energy> <billing_3phase_cumulative_reactive_lead_energy unit="kVArh">0.076250</billing_3phase_cumulative_reactive_lead_energy> <billing_3phase_power_factor>0.518</billing_3phase_power_factor> <billing_3phase_power_laglead>lag</billing_3phase_power_laglead> </billing_3phase_reset> </billing_3phase> <maximum_demand_3phase>...</maximum_demand_3phase> <load_survey_3phase>...</load_survey_3phase> <load_survey_apparent_energy_3phase>...</load_survey_apparent_energy_3phase> <load_survey_reactive_lag_energy_3phase>...</load_survey_reactive_lag_energy_3phase> <load_survey_reactive_lead_energy_3phase>...</load_survey_reactive_lead_energy_3phase> <load_survey_average_voltage_L1_3phase>...</load_survey_average_voltage_L1_3phase> <load_survey_average_voltage_L2_3phase>...</load_survey_average_voltage_L2_3phase> <load_survey_average_voltage_L3_3phase>...</load_survey_average_voltage_L3_3phase> <load_survey_average_current_L1_3phase>...</load_survey_average_current_L1_3phase> <load_survey_average_current_L2_3phase>...</load_survey_average_current_L2_3phase> <load_survey_average_current_L3_3phase>...</load_survey_average_current_L3_3phase> <tamper_3phase>...</tamper_3phase> </reading>
How can i get tag names from this document?
Sathishkumar C.
Hi @Sathishkumar_C wondering if you have tried the XML parser tool you can access this from the marketplace Universal Converter Extension it should give you the namespaces out in infotable.
Well actually ThingWorx Server Side Javascript supports Ecma Script for XML -- > E4X, you can work with XML documents out of the box, just look on E4X documentation.
