Access to the specified resource has been forbidden. I try connect REST to Thingworx with POSTMAN:https://aca-uef.elisaiot.com/Thingworx/Things/HTU21DThing/Services/setTempAndHumid?appKey=...&method=post&x-thingworx-session=true&Temperature=998.00&Humidit
jbjörkqvist
The Content Type what I used was text/html it should be application/json. I have to get off the parce functions in my Service also although there is generated json parce error. Bye
PaiChung
22-Sapphire I
(To:jbjörkqvist)
Do you have the Switch method on? the URL method=post only works with that on.
if you are using Postman you should just use POST instead of the URL switch
Like I said the Content Type that we used text/html it must be application/json. Method is POST. Than you for your caring.
