Reference documentation:
Tutorial A: Implement a Custom Connector Using ThingWorx Flow SDK
Tutorial B: ThingWorx Flow Connectors SDK Tutorial
Test locally through the above example, but there is an error, and the local configuration is as follows:
OAuth Connectors ,oauthGmail-gmail
"name": "oauthGmail-gmail",
"created_at": "2023-03-22T07:09:55.344Z",
"updated_at": "2023-03-22T07:09:55.344Z",
"uid": "6ad15babeeae449e9ccc7ac588cb9c60",
"icon": "Add name of the Connector icon",
"category": "",
"title": "Add title for the Oauth",
"oauth2_include": [],
"oauth2_required": [],
"oauth2_params_scope": [
"{\"https://www.googleapis.com/auth/gmail.labels\":\"Manage mailbox labels\"}",
"{\"https://www.googleapis.com/auth/gmail.insert\":\"Insert mail into your mailbox\"}",
"{\"https://www.googleapis.com/auth/gmail.modify\":\"All read/write operations except immediate, permanent deletion of threads and messages, bypassing Trash.\"}",
"{\"https://www.googleapis.com/auth/gmail.readonly\":\"Read all resources and their metadata—no write operations.\"}",
"{\"https://www.googleapis.com/auth/gmail.compose\":\"Create, read, update, and delete drafts. Send messages and drafts.\"}",
"{\"https://www.googleapis.com/auth/gmail.send\":\"Send email on your behalf\"}"
"oauth2_refresh_data": [
"{\"client_secret\":\"{client_secret}\"}",
"{\"grant_type\":\"refresh_token\"}",
"{\"client_id\":\"{client_id}\"}",
"{\"refresh_token\":\"{refresh_token}\"}"
"oauth2_refresh_url": "/token",
"oauth2_token_data": [
"{\"redirect_uri\":\"{redirect_uri}\"}",
"{\"grant_type\":\"authorization_code\"}"
"oauth2_token_url": "/token",
"oauth2_auth_query": [
"{\"response_type\":\"code\"}",
"{\"resource\":\"{resource}\"}",
"{\"scope\":\"{scope}\"}",
"oauth2_validate_url": "",
"oauth2_validate_method": "GET",
"oauth2_validate_headers": [
"{\"Authorization\":\"Bearer {access_token}\"}",
"{\"Content-Type\":\"application/json\"}"
"oauth2_auth_url": "/auth",
"oauth2_no_state": false,
"env_production_params": [],
"env_pre_prod_params": [
"{\"redirect_uri\":\"{OAUTH_ENDPOINT_OAUTH_RETURN}\"}",
"{\"client_id\":\"{{{pre_prod.CLIENT_ID}}}\"}",
"{\"client_secret\":\"{{{pre_prod.CLIENT_SECRET}}}\"}"
"env_staging_params": [],
"env_development_params": [
"{\"client_id\":\"{{{development.CLIENT_ID}}}\"}",
"{\"client_secret\":\"{{{development.CLIENT_SECRET}}}\"}"
"env_local_params": [
"{\"client_id\":\"{{{local.CLIENT_ID}}}\"}",
"{\"client_secret\":\"{{{local.CLIENT_SECRET}}}\"}"
"base_url": "https://accounts.google.com/o/oauth2/v2",
"oauth_type": "OAuth2",
"development_phase": "gold",
"advanced_enabled": true,
"express_enabled": false,
"deleted_at": null,
"published": true,
"__v": 0
.flow
.flow\flow.json
"hostname" : "flow.local.rnd.ptc.com",
"port" : 443
Execute the test command through cmd,Pop-up 404 box
flow test oauth oauthGmail-gmail -f ..\testOauthData.json -t "Test Gmail Oauth"
There are no logs in the .pm2 flolder
Could you tell me where the misconfiguration caused the problem?
Hi @XS_9736278.
Can you provide the version of ThingWorx you are running?
Regards.
--Sharon
