I am new to thingworx and have been playing around with the google map widget. I have requirement for a POC that I am working on where I need a dark themed Mapskin for the google map. I downloaded the extension .zip file from the market place and updated the goolgemap.ide.js and goolgemap.id.runtime.js files where I believe is the correct spot (see below) and also increased the version iteration in the metadata.xml. I am then able to load the extension into the composer, however after the extension is installed I cannot see to google maps widget as a menu option. Do I need to overwrite or uninstall the existing widget or modify the metadata.xml of the new widget?
googlemap.ide.js line 29:
'MapSkin': {
'isBindingTarget': false,
'description' : 'A few options on the look of the map',
'baseType': 'STRING',
'defaultValue': 'normal',
'selectOptions': [
{ value: 'normal', text: 'Normal' },
{ value: 'blue', text: 'Blue' },
{ value: 'gray', text: 'Gray' },
{ value: 'dark', text: 'Dark' }.
googlemap.ide.runtime.js line 146:
| switch( this.getProperty('MapSkin','normal') ) { | |||||
| case 'normal': | |||||
| break; | |||||
| case 'blue': | |||||
| options['styles'] = [{"featureType":"water","elementType":"geometry","stylers":[{"color":"#193341"}]},{"featureType":"landscape","elementType":"geometry","stylers":[{"color":"#2c5a71"}]},{"featureType":"road","elementType":"geometry","stylers":[{"color":"#29768a"},{"lightness":-37}]},{"featureType":"poi","elementType":"geometry","stylers":[{"color":"#406d80"}]},{"featureType":"transit","elementType":"geometry","stylers":[{"color":"#406d80"}]},{"elementType":"labels.text.stroke","stylers":[{"visibility":"on"},{"color":"#3e606f"},{"weight":2},{"gamma":0.84}]},{"elementType":"labels.text.fill","stylers":[{"color":"#ffffff"}]},{"featureType":"administrative","elementType":"geometry","stylers":[{"weight":0.6},{"color":"#1a3541"}]},{"elementType":"labels.icon","stylers":[{"visibility":"off"}]},{"featureType":"poi.park","elementType":"geometry","stylers":[{"color":"#2c5a71"}]}]; | |||||
| break; | |||||
| case 'gray': | |||||
| options['styles'] = [{"featureType":"landscape","stylers":[{"saturation":-100},{"lightness":65},{"visibility":"on"}]},{"featureType":"poi","stylers":[{"saturation":-100},{"lightness":51},{"visibility":"simplified"}]},{"featureType":"road.highway","stylers":[{"saturation":-100},{"visibility":"simplified"}]},{"featureType":"road.arterial","stylers":[{"saturation":-100},{"lightness":30},{"visibility":"on"}]},{"featureType":"road.local","stylers":[{"saturation":-100},{"lightness":40},{"visibility":"on"}]},{"featureType":"transit","stylers":[{"saturation":-100},{"visibility":"simplified"}]},{"featureType":"administrative.province","stylers":[{"visibility":"off"}]},{"featureType":"water","elementType":"labels","stylers":[{"visibility":"on"},{"lightness":-25},{"saturation":-100}]},{"featureType":"water","elementType":"geometry","stylers":[{"hue":"#ffff00"},{"lightness":-25},{"saturation":-97}]}]; | |||||
| break; |
case 'dark':
| options['styles'] = [{"featureType":"all","elementType":"labels.text.fill","stylers":[{"saturation":36},{"color":"#000000"},{"lightness":40}]},{"featureType":"all","elementType":"labels.text.stroke","stylers":[{"visibility":"on"},{"color":"#000000"},{"lightness":16}]},{"featureType":"all","elementType":"labels.icon","stylers":[{"visibility":"off"}]},{"featureType":"administrative","elementType":"geometry.fill","stylers":[{"color":"#000000"},{"lightness":20}]},{"featureType":"administrative","elementType":"geometry.stroke","stylers":[{"color":"#000000"},{"lightness":17},{"weight":1.2}]},{"featureType":"administrative","elementType":"labels","stylers":[{"visibility":"off"}]},{"featureType":"administrative.country","elementType":"all","stylers":[{"visibility":"simplified"}]},{"featureType":"administrative.country","elementType":"geometry","stylers":[{"visibility":"simplified"}]},{"featureType":"administrative.country","elementType":"labels.text","stylers":[{"visibility":"simplified"}]},{"featureType":"administrative.province","elementType":"all","stylers":[{"visibility":"off"}]},{"featureType":"administrative.locality","elementType":"all","stylers":[{"visibility":"simplified"},{"saturation":"-100"},{"lightness":"30"}]},{"featureType":"administrative.neighborhood","elementType":"all","stylers":[{"visibility":"off"}]},{"featureType":"administrative.land_parcel","elementType":"all","stylers":[{"visibility":"off"}]},{"featureType":"landscape","elementType":"all","stylers":[{"visibility":"simplified"},{"gamma":"0.00"},{"lightness":"74"}]},{"featureType":"landscape","elementType":"geometry","stylers":[{"color":"#000000"},{"lightness":20}]},{"featureType":"landscape.man_made","elementType":"all","stylers":[{"lightness":"3"}]},{"featureType":"poi","elementType":"all","stylers":[{"visibility":"off"}]},{"featureType":"poi","elementType":"geometry","stylers":[{"color":"#000000"},{"lightness":21}]},{"featureType":"road","elementType":"geometry","stylers":[{"visibility":"simplified"}]},{"featureType":"road.highway","elementType":"geometry.fill","stylers":[{"color":"#000000"},{"lightness":17}]},{"featureType":"road.highway","elementType":"geometry.stroke","stylers":[{"color":"#000000"},{"lightness":29},{"weight":0.2}]},{"featureType":"road.arterial","elementType":"geometry","stylers":[{"color":"#000000"},{"lightness":18}]},{"featureType":"road.local","elementType":"geometry","stylers":[{"color":"#000000"},{"lightness":16}]},{"featureType":"transit","elementType":"geometry","stylers":[{"color":"#000000"},{"lightness":19}]},{"featureType":"water","elementType":"geometry","stylers":[{"color":"#000000"},{"lightness":17}]}]; |
break;
Jason
Dumb question, but did you say yes to refresh Composer? You have to reload to see the custom widgets in extensions sometimes.
