AddPropertyDefinition on Thingworx display: Must Specify A Property Name
aziliotto
Hi, i have an issue adding dynamically properties to a remote template create by snippet.
I get an error reporting this:
JavaException: com.thingworx.common.exceptions.InvalidRequestException: Must Specify A Property Name
this is the code:
//template creation
var paramsRemoteThing = {
    description: "This is the description", // STRING
    thingTemplateName: 'RemoteThing',
    tags: 'MyParent:Template'
Resources["EntityServices"].CreateThingTemplate(paramsRemoteThing);
//add a remote property
var paramsIns = {
        defaultValue: undefined , // STRING
        description: undefined , // STRING
        readOnly: false,  // BOOLEAN
        type: "STRING",  // BASETYPENAME
        remote: false , // BOOLEAN
        remotePropertyName: "ThisIsMyNamedProperty" , // STRING
        timeout: undefined , // INTEGER
        pushType: "VALUE" , // STRING
        dataChangeThreshold: undefined,  // NUMBER
        logged: false, // BOOLEAN
        name: "variabile" , // STRING
        pushThreshold: undefined , // NUMBER
        dataChangeType: "VALUE" , // STRING
        category: "remote" , // STRING
        persistent: true, // BOOLEAN
        dataShape: undefined // DATASHAPENAME
    // try to add property
    try{
         ThingTemplates[nomeTemplate].AddPropertyDefinition(paramsIns );
    }catch(e){
         logger.error("ERROR adding proeprty:  "+e)
What am i missing ? after creating is necessary to bind remote property?
jlittle
(To:aziliotto)
You may want to have a look at KCS 237302 which goes through dynamically mapping properties on a Remote Thing.  There is mention of code on the Edge device, though ultimately it is simply triggering the Service defined on the Remote Thing Template to map the properties.
This will only work if you've defined your remote properties on your edge device.  (This example was specifically used with the Java Edge SDK when it was written)
aziliotto
(To:jlittle)
Thank you Jeremy!
It was a syntax error, now it works properly!
