I would like to know, is there a way to add getProperties() service to Mashup through Script in thingworx 7.2.
Penchalaiah
I think the easiest way is to have the necessary valuestreams created ahead of time and associated with the ThingTemplate(s)
We recommend minimizing the number of valuestreams, generally a single valuestream per ThingTemplate.
Can you please explain what you are looking to do with that and in what form?
Sounds like you want to dynamically create valuestreams and have that information come into a mashup programmatically??
Yes I would like add value streams dynamically
