If I increase the size of the label chart of type bar chart, the bar size rather width also increases accordingly. Is there any way to specify the width of the bars? So that we can have enough spacing between two bars
Also, can we change the colors getting used in Pie Chart?
Hi Suraj,
The bar sizes adjust automatically based on the given
axes, and can't be changed individually. The only workaround, as you
mentioned, is changing the entire size of the Label Chart.
Changing the colors in a Pie Chart is a new feature available starting with the next release of ThingWorx.
