Advance Grid Sorting - double digit numbers not working
LP_10027711
hello. i have sorting setup for an advance grip and when i click the column with double digit numbers, it sorts only from 0-9. see pictures
1 ACCEPTED SOLUTION
Had to use a regular "grid" widget to get the sorting working.
Hello @LP_10027711,
I have not worked with the sort, so I may be wrong, What is the data type of the column you are sorting?
My question is do you want a numeric sort or a string sort. the results are different
LP_10027711
(To:PEHOWE)
its a number data type
