After deleting a thing by script, the remote EMS is still trying to connect and try to send data. This lead to many, many error entries in the log
"Unable to dispatch [ uri = /Things/xxxxx/Services/UpdateSubscribedPropertyValues/]: Entity xxxxx does not exist or is not yet associated with a Thing"
and
"error executing APIRequest Message: Entity xxxxx does not exist or is not yet associated with a Thing, sending ERROR ResponseMessage to caller!".
How to stop these messages?
BTW: It is correct, the xxxxx thing is and shall be deleted!
Since the EMS is able to connect, it will connect, however maybe it is thinking it is still able to bind.
otoh depending on how your ems is set up, you might be directly trying to send info to a particular thing.
I would recommend restarting Thingworx to see if some of these go away.
Regardless of the associated Thing being deleted though, the EMS will connect since that depends on the appkey not the Remote Thing
I don't think all of Thingworx needs to be restarted, just the EMS/LSR. I take it you're not stopping the LSR/EMS right? Can you provide more details about how you have your EMS and LSR setup? Your feedback is useful so I'm curious what you would expect to happen in this scenario. If you stop the LSR I believe the messages will stop. Is that not an option?
for more details please see my answer to Pai Chung
Step 1
After restart of ThingWorx and the Remote Things the start situation is as follows.
Step 2
After double-click in table on an unbound thing (#1), then service starts a thing deletion script:
Then a thing creation script is started:
The mashup shows the data of the thing #1 (now it is not unbound anymore, because the corresponding thing exists)
At this time no additional entries in the application log.
Everything looks fine at this step.
Step 3
After double-click in table on an unbound thing #2, then service starts a thing deletion script:
The mashup shows the data of the thing #2 (now #1 is unbound)
Now a lot of entries written to the application log from remote thing #1.
The question is how to come to a situation like end of step 1 or 2 where several remote things running but not logging after deleting a thing (e.g. #1).
Thanks for those very detailed steps Werner. I think I'm still doing something differently than you are because for me as soon as I turn on my local ThingWorx instance, start the ems (without auto-bind), and then start the luaScriptResource.exe I get the same style error in my log. What I mean is that for me - Step 1 as you outlined above produces the error message. As soon as I turn off the LSR - the errors stop.
Here are the steps I followed:
I am using ThingWorx 7.4.2 and EMS 5.3.2.
