Alignment of mashup is not working as expected while using POPup in thingworx
KV_10974131
8-Gravel
Hello
I have a responsive mashup and i am using navigate function to open mashup in a popup window .
But the alignment is never set to the way i want to use it always behave differently
Any help will be appreciated
Hello @KV_10974131 ,
As I can check, this is NOT possible in ThingWorx 9.3 version. You may refer the below linked article for your reference:
https://www.ptc.com/en/support/article/CS416898
Bhawna
could you pls provide the following info for better understanding:
1. Version of ThingWorx
2.Are you customizing the Popup window or Mashup window?
Bhawna
@KV_10974131  Also Share the sample entities (if feasible).
Hello @bchaudhary
1) Twx version is 9.3
2) I am not sure what do you mean by customization here , i am just trying to set its dimensions.
Sharing entities won't be possible.
Bhawna
