Hi there,
I am trying to install Thingwors HA on ubuntu and windows servers. Most of my machine's OS are Ubuntu except Analytics server, which is installed on a Win2016 server. After installed HA, everything worked fine. But when I installed analytics server, I found all the analytics related things were not created. I tried to reinstall several times, but the same results. I looked into the install log under Analytics Server folder, and found records as below.
Checking if Remote Things are created...
Setting variable remoteThingConnectionStatus from C:\PROGRA~1\THINGW~1\THINGW~1\scripts\http_post.exe 10.158.190.150 8080 **** false true /Things/WIN153-AnalyticsServer/Services/GetBooleanPropertyValue {\"propertyName\":\"isConnected\"} result
Script exit code: 1
Script output:
HTTP status 404
Could you please help to deal with it?
Thank you.
Thank you for your post on the PTC Community.
When deploying ThingWorx Analytics Server, and connecting to a ThingWorx Platform Server running in HA mode, you need to use the Load Balancer hostname as used by client to connect to ThingWorx for the endpoint.
If this does not resolve your problem, please open a support case and the tech support engineer will assist you in getting you up and running.
https://www.ptc.com/en/support/case-logger
Neel
Hi @WF_9880450
I'm reaching out to our Analytics subject matter experts to get an answer to your post.
Regards.
--Sharon
Neel
Hi @WF_9880450
If you feel the response from Neel answered your question, please mark it as the Accepted Solution for the benefit of others in the community.
Regards.
--Sharon
