Association between two things from different templates
vijay5
11-Garnet
Hi Team,
Need assistance on accomplishing association between things of different templates(that doesnot have inheritance between them) may be primary and foreign key relation or must use a dataTable to achieve this?
Can any one pls suggest
PaiChung
22-Sapphire I
(To:vijay5)
Thing1 would have a property that helps it to 'maintain' what other Thing(s) it 'relates' to
so I could do something like
Things[me.myRelatedThing].someValue to access a property value in that related Thing.
PaiChung
22-Sapphire I
(To:vijay5)
Often times we use a Network for this.
Not sure if there is an actual hierarchical relationship
else you can use a property in either Thing to 'point' to the other Thing
vijay5
11-Garnet
(To:PaiChung)
Thanks for the reply
Can you pls brief on
PaiChung
22-Sapphire I
(To:vijay5)
vijay5
11-Garnet
(To:PaiChung)
Thanks, Got it
