I try to style my Mashups with custom css, but I don't know where to find the syntax for the widget classes. For example: my collection widget has a custom class (customfoo). Now I can style it in the css, but how do I access for example the cells in it (or any other element)?
Hello, mplieske! Thanks for posting your question.
Take a look at the Custom Class Widget Css Quickstart and see if that is able to get you going with this.
Thank you,
-- Craig A.
Thank you,
-- Craig A.
