Authenticator which will return 401 unauthorized on bad credentials and not execute system authenticators
jacekgra
Is it possible to write custom authenticator that will:
1) Has top priority (executed first) - YES
2) Be executed only when certian header will be present in the request - YES
3) Return 401 Unauthorized if credentials will be wrong AND respond to the user immedietally without executing system authenciators (HTTP BASIC etc) - ???
keriw
(To:jacekgra)
you can have it do custom checks as the first part of your authenticator and if your custom checks fail you should be able to then use
httpResponse.sendError(HttpServletResponse.SC_UNAUTHORIZED, "your message goes here");
keriw
(To:jacekgra)
