AutoComplete widget Issue
I was using Selected Value Field from Autocomplete widget. Now I imported latest version of Autocomplete and the selected value field is not passing the value to the services. So I reverted to the old extension which was used before this change. Now also selected value field is not present in properties of Autocomplete widget. No logs generated for this. Iam clueless about what is happening here. Anyone can add ideas to fix this as it is causing critical issue in customer environment.
