Azure TimeSeriesInsight to ThingWorx
RodrigoAA
Good afternoon,
I am trying to pull some data from Azure TSI to my ThingWorx Project/Mashup. I have checked connectors and services functionalities but I don't find the way to create this connection using the available documentation.
Could you suggest an approach or methodology (step by step) about how to do it?
Open questions
How can I integrate a HTTP connector into an Oauth 2.0 schema? Is there a common method of performing it?
Do I have to provide bearer token myself? Or does ThingWorx provides a way to obtain it?
Thank you very and sorry for not being more specific.
Regards, Rodrigo.
There is no solution available in PTC to connect Azure TimeSeriesInsight to Thingworx.
We are providing an extension to connect only Azure IOT Hub, this is Azure Iot Connector Extension.
Thank you,
Raluca Edu
Thank you,
Raluca Edu
slangley
(To:RodrigoAA)
Hi @RodrigoAA.
Just an FYI...Azure TimeSeriesInsight is on the roapmap for a future release of ThingWorx.
Regards.
--Sharon
