Hi ,
I am looking to retrieve shiftName value from current datetime as below .
if Current date is between Start_Date and End_time then return shift name.
how to do it using query or any functions in TWX?
Hi @smainente & @PaiChung ,
Thanks for the reply.
Below code works for me..
var query = {
"filters":{
"type": "LT",
"fieldName": "Start_Date",
"value": date
var result1= Things["AAL.MPS.ShiftConfig.DT"].QueryDataTableEntries({
values: undefined /* INFOTABLE */,
maxItems: undefined /* NUMBER */,
tags: undefined /* TAGS */,
source: undefined /* STRING */,
query: query /* QUERY */
var query1 = {
"filters":{
"type": "GT",
"fieldName": "End_Time",
"value": date
// Provide your filter using the format as described in the help topic "Query Parameter for Query Services"
var params = {
t: result1 /* INFOTABLE */,
query: query1 /* QUERY */
var result2 = Resources["InfoTableFunctions"].Query(params);
You can use any of the Query services, or the infotable query and use the Between filter
Just some addition to @PaiChung comment (I don't know if it is relevant to your use case - maybe you just want to manipulate an in memory InfoTable )
It is important to know that if you use a query filter on a service that queries persisted data (Steam, DataTable), the filter is always applied in-memory on the platform.
For example :
var query = {...};
var result = Things["myStream"].QueryStreamEntriesWithData({maxItems: 1, query: query});
If "myStream" contains 5 millions entries, 5 millions records will be fetched from the DB, then filtered by the platform.
See https://community.ptc.com/t5/IoT-Tech-Tips/Note-about-Data-Tables-and-Streams-Query-APIs/td-p/691120
var query = {
"filters":{
"type": "LT",
"value": date
var query1 = {
"filters":{
"type": "GT",
"value": date
var params = {
Hi @VaibhavShinde.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
