Below pic is the legend from the Line chart, but was not able to find the border radius for the check box and the marker !!
How can the border radius can be given to the Check box and marker !!
@c_lowy @CarlesColl @slangley
Shashi
The line chart legend has 2 items displayed for each line on the graph, a color sample to link the legend to the graph and a check box which allows the line to be turned on and off. The shape of the color sample can be modified by property "LegendMarkerShapes".
It is not currently possible to modify the color sample, check box or legend using CSS. The access to the items has not been exposed.
Please file an item in "ThingWorx Ideas" group to have the feature added.
Hello @pshashipreetham,
Have you considered the Line Chart properties "LegendMarkerShapes" there are 3 options, none, square, and circle.
Have you used this option?
Does this meet your needs.
Hey @PEHOWE ,
This will not help, looking to set the Border Raider for those markers.
Shashi
