Hi @adityak506
Here are some options:
1) Using the CSVParser extension you can export the Stream Value data to a csv file. Then you can use this csv file to create a dataset inside ThingWorx Analytics Builder.
2) You can also do this in a automatic way:
Hope this helps
Christophe
Hi @adityak506
Hope this helps
Christophe
Thanks Christophe
