Hi @adityak506
Here are some options:
1) Using the CSVParser extension you can export the Stream Value data to a csv file. Then you can use this csv file to create a dataset inside ThingWorx Analytics Builder.
2) You can also do this in a automatic way:
- use QueryNumberPropertyHistory() service to retrieve the Value stream data
- loop through all the desired records to build an infotable that will represent the dataset data
- create a info table using the AnalyticsDatasetRef datashape to build the dataset infotable.
- pass this dataset infotable to the AnalyticsServer_DataThing.CreateDatasetWithDatasetRef().
Note if you want to see the dataset in Builder, add the tags builderdataset and builderdatasetname:<your dataset name>
Hope this helps
Christophe
