Is it possible to create a CAPTCHA check in a mashup to prevent bots?
Is there an extension for this?
Any help would be greatly appreciated.
Many thanks
Ashley
There is no extension for this though a widget extension likely could be possible. This currently was not considered a need since you have to authenticate with the Thingworx platform in order access any mashup. A bot would need to be able to pass the authentication first.
