Is it possible to call a Thing service from the Custom CSS of a mashup? If so, how?
Example:
.label .widget-ptcslabel::part(label) {
display: Things["Thing"].service({
ProcessOrderNo: ProcessOrderNo /* STRING */});
Better late then never.
From what I know this is not possible no.
If you want to do something based on a service, you would have to use mashup functions like an expression or use a service to return a string with which custom CSS class to use.
Something like:
if (useClass1) {
output = 'class1';
} else if (useClass2) {
output = 'class2';
And then just bind this output to your customClass property on the widget you want to target.
It is a little cumbersome I agree, but as we can't use jQuery or similar in functions, this is the only way I know how.
Jens
Something like:
if (useClass1) {
output = 'class1';
output = 'class2';
Jens
