Can I store grid row value to DB
HemalathaMsk
7-Bedrock
      On button click I would like to get all data's from grid and want to store in DB.   Is it possible?
Hema
Hi Hemalatha, indeed this should be doable just by calling the same service which you are using to show data in the grid; looping the result set (will basically involve lopping over the Infotable) and then calling the insert into table statement for your external Database.
You can put above logic in a single service or may be create a JS service which wraps a SQL service and then have this invoked on button click event.
Hope this helps.
Thanks it will work.
Hema
