I have trouble with the demo Analytics Model in Analytics Manager. Everytime I try to delete is I get the message "Model: JetEnginePredictiveModel can't be deleted, is in use by a Job!". If I watched by Analytics Jobs in Analytics Manager I didn't see any jobs. The statistic of the last 1000 jobs says Completed: 5 but the list is empty. It there any way to delete is? Maybe in filesystem or so?
Hi David,
By default the Completed jobs are filtered and not visible.
To see them you need to untick the box "Filter Completed Jobs"
Hope this helps
Regards
Christophe
Hi David,
Hope this helps
Regards
Christophe
Thx a lot
How I can delete all job at once...I have a list of jobs and I can't select all at a time and delete.
Got a solution...Thanks!!
