I want to view the data in tree widget which has 2 parent nodes. I want to view the data in this way
s1
|-- s2
|-- s3
|-- s4
s5
|-- s6
|--s2
In a Network you can't do this.
But you can try just creating the infotable with nodes setup the way you want and bind that to the tree widget
remember that in that setup
parent child
a top node is a CHILD without a parent.
so you would have
parent child
s1
s1 s2
s5
s5 s6
s6 s2
parent child
so you would have
parent child
s1
s1 s2
s5
s5 s6
s6 s2
Thanks for the response.
