I would like to add effective token onto a ressources.
So I could find them back later by using GetEffectiveToken()
Is It possible?
Cordially.
Tokens can be created/added by using the 'AddToken' service, 'GetEffectiveToken()' is specifically for within Mashup runtime, but you can also use 'GetToken'
Not sure what your use case is in this case.
