Is there a way to change the Grid Header Height? I can adjust my row heights within the Grid widget but even if I upscale the text size for the style that is assigned to the Grid Header, it doesn't get any bigger.
Hi Michael,
Unfortunately, increasing or decreasing the text size of the header text is currently not supported. I've logged this issue to our issue tracker.
Adam
Hi adam do you know if there is any way to remove it completely?
Thank you.
