I am using the LabelChart widget, and need to change the color of the line based on state formatting. Is this possible? Should I use another type of chart widget?
I've been able to change the color of the 'on hover' action based on state formatting (by using the 'SeriesDataStyle1' property of the widget), but not the line itself.
Hi @ague.
It is possible to edit the color of the line using either CSS or style definitions/state formatting based on the needs of your use case. But in the case of a line, what criteria determines the line color?
If this does not guide you to a solution, please provide more details around your requirements.
Regards.
--Sharon
Hi @ague.
If my previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
Hi @ague.
If you have found a solution to your issue, your indulgence in posting it here for the benefit of other community members would be greatly appreciated.
Regards.
--Sharon
Your response did not answer my question.
You say I can do this with CSS - can you send me an example? I have a boolean value that I want to use as a state based formatting - if true, line is green; If false, line is red.
Hi @ague.
If you have found a solution to your issue, please post it here and mark it as the Accepted Solution. If one of the previous responses allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others with similar questions.
Regards.
--Sharon
I haven't found a solution to this issue - my team abandoned trying to research this and we've already moved forward with another option.
But, from the bit of research I did do before going another route, I think the answer is that it is not possible to do this in ThingWorx.
