In ThingWorx 9.1 I have a Dropdown widget with MultSelect enabled. When I view the mashup and select the Dropdown, the "Select All" text at the top is yellow, hard to see with a white background. I want to change the color of that text but I can't find a style that changes it. I expect I need to use a CSS ID, but I never have much luck finding those. Any ideas?
Thanks for your feedback with the PTC case, Sharon.
The solution is to update the Style Theme under Navigation > Secondary Links and change the Active State and Hover State colors.
Hi @DanWolf
We validated the same issue, and when using CSS, it only changed the color of the first row. Therefore, I will open a case on this issue.
Regards.
--Sharon
Thanks, Sharon!
