Is it possible to define a chart like this?
If yes what type of chart should be used?
Please provide some solution.
Thanks in advance,
V.Shalini.
I don't think (and others please correct me if I'm wrong) we have a great widget for this right now.
The Event Chart is sort of meant for this but I don't think it has the fill. I believe you can accomplish this with a label chart, but you will need to transform the data.
Hi Pai,
Thanks for your reply, I will try it with label chart. I also wanted to know this chart is possible? Its the combination of three data values (oee,availability,performance). How can I achieve it?
Can I get this exactly as in the image?
V.Shalini.
In the Marketplace there is a progress chart that will get close.
You may in the end have to create a custom widget.
