Is there any way to clear the selected item (un-select that item) in the List widget? I am actually trying to use it in the Dropdown mode as part of a search form.
There doesn't appear to be any way to directly unselect an item in a list in Dropdown mode. However, you can unselect an item in List and Radio Button modes if you check the box to enable MultiSelect. When this is enables, using Control-pick will unselect the selected item.
