Is there a way to clear the browser cache from thingworx?
Thanks in advance,
Shalini V.
Thank you for reaching out to PTC
Could you please explain your use case. I mean if you simply want to clear the browser cache that can be done by setting the browser to clear the temporary files on their exit. Please check this CS166422
Also, please check this community post if it helps you with your use case
Please feel free to reach out to us in case of any question/concern
Toolika Dixit
Toolika Dixit
Thank you for contacting PTC.
If you mean clearing the browser cache, then refer to @tdixit @ reply.
If you mean clearing the Apache cache, then refer to https://www.ptc.com/en/support/article/CS238915
Just in case, you cannot log in to this URL, I will paste the content here
BR,
Max
Hi @svisveswaraiya.
if you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
