Columns order problem Data Export Extension
gcakiroglu
Hi there,
I use Data Export Extension with for excel and pdf exports but i can't order columns. I had found solution in here​ then i tried CSV Parser Functions. Yes, it worked just for newReportInfoTable but result is like attachment;
How can i order columns when exporting?
var params = {
    inputInfoTable: reportInfoTable,
    orderedFieldList: 'Period,AverageMilSpeed,AverageEntryCoilDiameter,AverageExitCoilDiameter,AverageExitWidth'
result: INFOTABLE
var newReportInfoTable = Resources["CSVParserFunctions"].GetOrderedFieldOutput(params);
var params = {
    infotable: newReportInfoTable
var result = me.ExportInfotableAsExcel(params);
ttielebein
(To:gcakiroglu)
Sorry, what is the problem with the attachment? I am not sure I understand.
Hi Gokhan Cakiroglu​, So, the order is not correct in CSV as compared to the Service. Did you get any error in the logs?
Try passing the orderdedFieldList as an array if it helps.
