Hi All,
I am wanting to query an SQL Database which has several Tables within it and output an InfoTable with certain columns from different Tables.
Is this possible in a single SQL Query Service or should I create a custom JavaScript service which manipulates several SQL Query service outputs?
Many Thanks
Ashley
Hi Ashley Gibson,
Yes, it is possible in a single SQL Query Service.
I just tried following query from ThingWorx for my sql and it gives expected result.
SELECT `testtable1`.`field1`,
`testtable2`.`field2`
FROM `MySqlTestDB`.`testtable1`, `MySqlTestDB`.`testtable2` where `testtable1`.`field1`= `testtable2`.`field2`;
I hope it helps.
Ankit Gupta
Hi Ashley Gibson,
I hope it helps.
Ankit Gupta
Hi Ankit,
Many thanks for this input!
Ashley
