Hello All,
I am trying out things with Rest API. I am following the link mentioned below ThingWorx REST API Cheat Sheet and http://support.ptc.com/cs/help/thingworx_hc/thingworx_7.0_hc/ .
Method= POST
http://localhost:8080/Thingworx/Resources/EntityServices/Services/CreateThing , authorization is basic auth, content-type and accept are application/json.
Json Format:
"name": "TestThing",
"description":"TestThingDescription",
"thingTemplateName":"TT_Test_API"
Response is 200k
2. I have enabled the thing using the following API
Method= PUT
http://localhost:8080/Thingworx/Things/TestThing/Services/EnableThing
Response is 200k
3. I am sending the following properties to the thing
Method= POST
http://localhost:8080/Thingworx/Things/TestThing/Services/addDetails?method=post&input=register
"register":{
"Unique_ID":"2002",
"Address":"Bangalore, India",
"Contact_Mobile_No":"8897388034",
"Contact_Name":"YOGESH"
In TT_Test_API(which is my template) and have written a service that fetch the data from the json what we are sending.I am able to do all these steps if i do them individually.
Can we merge all the steps mentioned above and create a consolodated API so that we can Create the thing,Enable the thing & send the data in a single shot???
Best Regards,
Babu Yogesh,
Dell
