having an issue with Japanese characters in Combobox widget, hoping someone can help.
In a mashup I have combo box widget which I fill with some data and then use the user selection to drive the rest of the mashup. This all seems to work correctly unless the list entry contains Japanese characters in which case the selection is not registered at all. There isn't even a Selection Changed' event fired off. I also tried this with some Vietnamese characters with the same result.
I added a display widget to show the selected item and this remains blank if an item with Japanese characters is chosen. Has anyone else had this occur.
Note it works correctly is I use a simple list widget.
TIA
K
Hi @khayes1.
Which version of ThingWorx are you using? This issue appears to be resolved in 9.0.
Regards.
--Sharon
