Compatibility of Thingworx Foundation 9.7.2 with Windows Server 2025
CN_12920402
3-Newcomer
Hello all,
I would like to install Thingworx Foundation 9.7.2 on a new server and would like to know if this version is compatible with Windows Server 2025 (since Windows Server 2022 will reach the end of standard support in 2026).
Thank you in advance for your support.
Rocko
(To:CN_12920402)
Release advisor only lists Windows Server 2022. https://release-advisor.ptc.com/releaseMatrix?releaseId=2434
So while it's highly possible it will run under Windows Server 2025, it will not be a supported configuration.
I recommend going to TWX 10 which will support WS 2025 later on (not yet).
Rocko
(To:CN_12920402)
CN_12920402
3-Newcomer
(To:Rocko)
Thanks you !
Hi @CN_12920402
It appears that this post may answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Abhi
