I have logged properties that I want to filter I'm writing a service to build a query based on the users selections however I've run into an issue.
It does not appear to support nested filters, any suggestions on how to approach this problem?
"filters": {
"type": "AND",
"filters": [
{"filters": {
"type": "OR",
"filters": [{
"fieldName": "gender",
"type": "EQ",
"value": "Male"
"type": "EQ",
"value": "Female"
{"filters": {
"type": "AND",
"filters": [{
"fieldName": "age",
"type": "GE",
"value": 50
"fieldName": "age",
"type": "LT",
"value": 60
In the JSON above the taking lines 5 - 18 or 19 - 32 as the queries work however when run it as a whole I get the following error message:
Unable to Invoke Service QueryPropertyHistory on myThing : JSONObject["type"] not found.
I want to provide three or more groups of filtering options where each group will filter based on one property. I need an 'AND' between each of the groups and in general there will be an 'OR' between the elements of the group. As I want to filter based on age groups rather than an actual value for this I will need and 'OR' and an 'AND' something like this...
"filters": {
"type": "AND",
"filters": [{
"filters": {
"type": "OR",
"filters": [{
"type": "EQ",
"value": "Male"
"type": "EQ",
"value": "Female"
"filters": {
"type": "OR",
"filters": [{
"filters": {
"type": "AND",
"filters": [{
"fieldName": "age",
"type": "GE",
"value": 50
"fieldName": "age",
"type": "LT",
"value": 60
"filters": {
"type": "AND",
"filters": [{
"fieldName": "age",
"type": "GE",
"value": 30
"fieldName": "age",
"type": "LT",
"value": 40
Did you ever receive an answer for this? I am running into same problem.
From the Thingworx documentation:
Nesting Filters with Different And/Or Types
"type":"AND",
"type":"OR",
"fieldName":"Status",
"type":"LIKE",
"value":"*-none-*"
"type":"LIKE",
"value":"empty"
"fieldName":"IsDeleted",
"type":"EQ",
"value":false
You're creating too many Filter's objects, that only exists as an object at the top level, the rest are arrays.
I think this is what you want, but it's difficult without being able to test:
"filters":{
"type":"AND",
"filters":[
"type":"OR",
"filters":[
"fieldName":"gender",
"type":"EQ",
"value":"Male"
"type":"EQ",
"value":"Female"
"type":"OR",
"filters":[
"type":"AND",
"filters":[
"fieldName":"age",
"type":"GE",
"value":50
"fieldName":"age",
"type":"LT",
"value":60
"type":"AND",
"filters":[
"fieldName":"age",
"type":"GE",
"value":30
"fieldName":"age",
"type":"LT",
"value":40
