Confusion about architecture
Gavin2
8-Gravel
Hello everyone,
I am now working on Thingworx architecture investigation, and I'm got a problem:
I use two connection server for device connectivity Load balance, I believe with this deploy mode, the architecture here is scalability
After that, the message received by connection server is send to Thingworx server. I know Thingworx server has a master-standby election based on zk-cluster
But in this way, I think there is only one live node(master) at a time, so I believe this is the performance bottleneck here, this can not expand dynamically
I don't know if I understand this right or not, can anyone help me to explain this
Thanks in advance
PaiChung
22-Sapphire I
(To:Gavin2)
You are correct, the Active/passive Thingworx platform is just for failover.
At this time there is no horizontal scalability of the platform itself, i hear this is in the works.
PaiChung
22-Sapphire I
(To:Gavin2)
Leigh
Emeritus
(To:Gavin2)
Hi @Gavin2
Just wanted to follow up to see if Pai's response answered your question.  If so, please indicate Accepted Solution for the benefit of the Community.  If not, please let us know your current status.
Leigh
