How can we connect the Proficy Historian Tags to Analytics Server for Predictive Maintenance ?
gone through all the docs, didn't find any way to do that ...
@slangley @PaiChung
Shashi.
Although there may not be anything OOTB or custom extension for this at this time.
I believe Proficy can be accessed through a REST API and there are some JDBC drivers available as well.
Either of these would allow you to pull the data from Proficy to send it to Analytics.
Hi @PaiChung ,
Thanks for the quick reply, can we connect a service out put the Analytics Server, services like "QueryNamedPropertyHistory" for the predictive maintainance
Shashi.
QueryNamedPropertyHistory is a specific service to retrieve data from the value stream, that wouldn't get you proficy data
