Hello everyone,
I'm trying to connect my Raspberry Pi to a private server of Thingworx. The server's address starts with http and continues with the IP adress of the server (ex: http://192.xxx.xx.xx/Thingworx/Composer/index.html). I followed Raspberry Pi Quickstart guide (https://developer.thingworx.com/resources/guides/thingworx-raspberry-pi-quickstart) and I managed to build a connection between my RasPi and academic cloud of Thingworx by establishing and configuring the Edge Micro Server (EMS). When I tried to adapt this solution to my case I got the ERROR: Error initializing socket connection. Er = 113. I'm not sure if i defined port and protocol wrong. I also use static IP for my RasPi since the Wifi I use is private and doesn't allow access to internet.
Thank you for your attention,
Emre
I am having a similar issue however I am able to connect unsecured just fine. I am trying to enable SSL via port 8443 and have been having issues. I have tried other devices (browser, etc) and can connect to composer in a secured fashion using 8443 however no luck with the PI.
I have tried a number of different options for the certificates. My end goal is to have the pi use client authenticataion via 8443 but I need to be able to connect via 8443 first.
This is my config.json:
"ws_servers": [{
"host": "XX.XX.XX.XX",
"port": 8443
"appKey": "XXXXXXXXX",
"certificates": {
"cert_chain": [ "/home/pi/keystore/CARoot.cer" ],
"allow_self_signed": true
"http_server": {
"host": "127.0.0.1",
"port": 9080
"logger": {
"level": "TRACE"
"auto_bind": [{
"name": "RedPi",
"gateway": false
"certificates": {
"validate": false,
"ws_connection": {
"encryption": "none",
"verbose": true,
"msg_timeout": 1000
Lets start by eliminating a cipher suite mismatch. Add the following to your tomcat configuration:
Add the following cipher suites in server.xml and restart the tomcat.
<Connector port="8443"
protocol="org.apache.coyote.http11.Http11NioProtocol"
acceptorThreadCount="2"
maxThreads="1000"
socket.txBufSize="24576"
scheme="https"
secure="true"
SSLEnabled="true"
keystoreFile="keystore.jks"
keystorePass="password"
clientAuth= "false"
sslProtocols = "TLSv1,TLSv1.1,TLSv1.2"
ciphers="TLS_RSA_WITH_AES_128_CBC_SHA256,TLS_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_256_CBC_SHA256,TLS_RSA_WITH_AES_256_CBC_SHA,SSL_RSA_WITH_RC4_128_SHA" />
Then let me know if you can connect.
Hey Bill,
I tried your suggestion. however still having an issue. I disabled port 8080
(1) Raspberry Pi config:
"ws_servers": [{
"host": "192.168.20.37",
"port": 8443
"appKey": "f109ecb5-9e2b-4215-8d3f-6479d5d6b9c1",
"certificates": {
"validate": false,
"http_server": {
"port": 9080
"logger": {
"level": "TRACE"
"auto_bind": [{
"name": "RedPi",
"gateway": false
"certificates": {
"validate": false,
"ws_connection": {
"verbose": true,
"msg_timeout": 1000
(2) Server.xml based on your suggestion:
maxThreads="1000"
scheme="https"
secure="true"
SSLEnabled="true"
keystoreFile="conf/tomcat.keystore"
keystorePass="XXXXXXX"
clientAuth= "false"
Log from PI:
pi@piRed:~/ems/microserver $ sudo ./wsems
[INFO ] 2017-05-30 15:30:32,346 ./wsems: Using config file: /home/pi/ems/microserver /etc/config.json
[FORCE] 2017-05-30 15:30:32,347 ./wsems: Starting up ....
[FORCE] 2017-05-30 15:30:32,348 ./wsems: Initializing EMS ....
[FORCE] 2017-05-30 15:30:32,348 main: Using config file /home/pi/ems/microserver/etc /config.json
[INFO ] 2017-05-30 15:30:32,348 ./wsems: Creating the WsEms proxy.
[INFO ] 2017-05-30 15:30:32,348 ./wsems: Starting HTTP Server.
[INFO ] 2017-05-30 15:30:32,348 ./wsems: Initializing the ThingWorx REST interface.
[FORCE] 2017-05-30 15:30:32,348 httpServer: starting http server port=9080
[ERROR] 2017-05-30 15:30:32,349 httpserver: Server socket error: Address already in use [127.0.0.1:9080]
[ERROR] 2017-05-30 15:30:32,349 httpServer: unable to bind http server to port=9080, trying next port.
[DEBUG] 2017-05-30 15:30:32,350 SDK: twWs_Create: Initializing Websocket Client for 192.168.20.37:8443//Thingworx/WS
[DEBUG] 2017-05-30 15:30:32,350 SDK: twTlsClient_Create: Initializing TLS Client
[ERROR] 2017-05-30 15:30:32,350 httpserver: Server socket error: Address already in use [127.0.0.1:9081]
[ERROR] 2017-05-30 15:30:32,351 httpServer: unable to bind http server to port=9081, trying next port.
[DEBUG] 2017-05-30 15:30:32,351 SDK: twApi_Initialize: Websocket Established after 0 tries
[DEBUG] 2017-05-30 15:30:32,351 SDK: subscribedPropsMgr_Initialize: Initializing sub scribed properties manager
[DEBUG] 2017-05-30 15:30:32,352 httpServer: http server bound to port=9082.
[DEBUG] 2017-05-30 15:30:32,357 jsonConfigurator::getJsonEntity: Key validation_crit eria not found
[DEBUG] 2017-05-30 15:30:32,358 jsonConfigurator::getJsonEntity: Parent file not fou nd
[INFO ] 2017-05-30 15:30:32,358 wsEmsProxy::initialize: Initialization complete!
192.168.20.37:8443-->[INFO ] 2017-05-30 15:30:32,359 ./wsems: Starting the connectio n.
[DEBUG] 2017-05-30 15:30:32,361 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:30:32,361 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:30:42,362 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 15:30:42,362 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:30:42,363 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-05-30 15:30:47,363 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:30:47,364 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:30:57,364 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 15:30:57,365 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:30:57,365 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-05-30 15:31:02,365 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:31:02,366 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:31:12,366 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 15:31:12,367 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:31:12,367 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-05-30 15:31:17,369 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:31:17,369 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:31:27,369 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 15:31:27,370 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:31:27,370 SDK: twTlsClient_Connect: Connecting to server
[WARN ] 2017-05-30 15:31:32,364 Main: Unable to connect to server. Trying .booted c onfig file
[WARN ] 2017-05-30 15:31:32,371 WsEmsProxy::execute() : Server connection failed. E rror Code: 201
[FORCE] 2017-05-30 15:31:32,475 Main: Shutdown signal received. Restarting ....
[DEBUG] 2017-05-30 15:31:32,475 SDK: twMessage_Send: Not authenticated yet
[ERROR] 2017-05-30 15:31:32,475 SDK: twMessage_Send: Error sending Message with Requ estId 1
[ERROR] 2017-05-30 15:31:32,476 SDK: twApi_UnbindThing: Error creating sending Unbin d message
terminate called without an active exception
[INFO ] 2017-05-30 15:35:51,285 ./wsems: Using config file: /home/pi/ems/microserver /etc/config.json
[FORCE] 2017-05-30 15:35:51,286 ./wsems: Starting up ....
[FORCE] 2017-05-30 15:35:51,286 ./wsems: Initializing EMS ....
[FORCE] 2017-05-30 15:35:51,286 main: Using config file /home/pi/ems/microserver/etc /config.json
[INFO ] 2017-05-30 15:35:51,286 ./wsems: Creating the WsEms proxy.
[INFO ] 2017-05-30 15:35:51,286 ./wsems: Starting HTTP Server.
[INFO ] 2017-05-30 15:35:51,288 ./wsems: starting http server port=9080
[FORCE] 2017-05-30 15:35:51,289 httpServer: starting http server port=9080
[ERROR] 2017-05-30 15:35:51,289 httpserver: Server socket error: Address already in use [127.0.0.1:9080]
[ERROR] 2017-05-30 15:35:51,289 httpServer: unable to bind http server to port=9080, trying next port.
[DEBUG] 2017-05-30 15:35:51,289 SDK: twWs_Create: Initializing Websocket Client for 192.168.20.37:8080//Thingworx/WS
[DEBUG] 2017-05-30 15:35:51,289 SDK: twTlsClient_Create: Initializing TLS Client
[ERROR] 2017-05-30 15:35:51,289 httpserver: Server socket error: Address already in use [127.0.0.1:9081]
[ERROR] 2017-05-30 15:35:51,290 httpServer: unable to bind http server to port=9081, trying next port.
[DEBUG] 2017-05-30 15:35:51,290 httpServer: http server bound to port=9082.
[DEBUG] 2017-05-30 15:35:51,290 SDK: twApi_Initialize: Websocket Established after 0 tries
[DEBUG] 2017-05-30 15:35:51,290 SDK: subscribedPropsMgr_Initialize: Initializing sub scribed properties manager
[DEBUG] 2017-05-30 15:35:51,291 jsonConfigurator::getJsonEntity: Key cert_chain not found
[DEBUG] 2017-05-30 15:35:51,291 jsonConfigurator::getJsonEntity: Key validation_crit eria not found
[DEBUG] 2017-05-30 15:35:51,292 jsonConfigurator::getJsonEntity: Parent file not fou nd
[DEBUG] 2017-05-30 15:35:51,293 jsonConfigurator::getJsonEntity: Parent file not fou nd
[INFO ] 2017-05-30 15:35:51,293 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2017-05-30 15:35:51,294 ./wsems: Starting the connection.
192.168.20.37:8080-->[DEBUG] 2017-05-30 15:35:51,296 SDK: twTlsClient_Reconnect: Re- establishing SSL context
[DEBUG] 2017-05-30 15:35:51,297 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:35:51,298 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:35:51,298 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:35:56,299 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:35:56,299 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:35:56,300 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:35:56,300 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:01,300 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:01,301 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:01,301 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:01,301 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:06,302 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:06,302 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:06,303 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:06,303 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:11,303 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:11,303 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:11,304 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:11,304 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:16,305 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:16,305 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:16,305 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:16,306 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:21,306 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:21,307 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:21,307 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:21,308 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:26,308 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:26,308 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:26,309 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:26,309 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:31,310 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:31,310 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:31,311 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:31,311 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:36,311 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:36,311 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:36,312 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:36,312 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:41,313 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:41,313 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:41,314 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:41,314 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:46,315 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:46,315 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:46,316 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:46,316 SDK: twWs_Connect: Error restarting socket. Error 1 11
[DEBUG] 2017-05-30 15:36:51,316 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:36:51,317 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-05-30 15:36:51,317 SDK: Error intializing socket connection. Err = 111
[ERROR] 2017-05-30 15:36:51,317 SDK: twWs_Connect: Error restarting socket. Error 1 11
[WARN ] 2017-05-30 15:36:51,324 Main: Unable to connect to server. Trying .booted c onfig file
[WARN ] 2017-05-30 15:36:56,318 WsEmsProxy::execute() : Server connection failed. E rror Code: 1001
[FORCE] 2017-05-30 15:36:56,420 Main: Shutdown signal received. Restarting ....
[DEBUG] 2017-05-30 15:36:56,421 SDK: twMessage_Send: Not authenticated yet
[ERROR] 2017-05-30 15:36:56,421 SDK: twMessage_Send: Error sending Message with Requ estId 1
[ERROR] 2017-05-30 15:36:56,421 SDK: twApi_UnbindThing: Error creating sending Unbin d message
[DEBUG] 2017-05-30 15:36:56,421 SDK: twMessage_Delete: Deleting BIND Message: 1
[INFO ] 2017-05-30 15:44:42,861 ./wsems: Using config file: /home/pi/ems/microserver /etc/config.json
[FORCE] 2017-05-30 15:44:42,862 ./wsems: Starting up ....
[TRACE] 2017-05-30 15:44:42,862 jsonConfigurator::getString: Key = audit_target, Par ent = logger
[TRACE] 2017-05-30 15:44:42,862 jsonConfigurator::getValueByType: Key audit_target n ot found
[TRACE] 2017-05-30 15:44:42,863 jsonConfigurator::getString: Key = publish_directory , Parent = logger
[TRACE] 2017-05-30 15:44:42,863 jsonConfigurator::getValueByType: Key publish_direct ory not found
[TRACE] 2017-05-30 15:44:42,863 jsonConfigurator::getUnsignedInteger: Key = max_file _storage, Parent = logger
[TRACE] 2017-05-30 15:44:42,864 jsonConfigurator::getValueByType: Key max_file_stora ge not found
[TRACE] 2017-05-30 15:44:42,864 jsonConfigurator::getString: Key = publish_level, Pa rent = logger
[TRACE] 2017-05-30 15:44:42,864 jsonConfigurator::getValueByType: Key publish_level not found
[TRACE] 2017-05-30 15:44:42,864 jsonConfigurator::getBoolean: Key = auto_flush, Pare nt = logger
[TRACE] 2017-05-30 15:44:42,864 jsonConfigurator::getValueByType: Key auto_flush not found
[FORCE] 2017-05-30 15:44:42,865 ./wsems: Initializing EMS ....
[FORCE] 2017-05-30 15:44:42,865 main: Using config file /home/pi/ems/microserver/etc /config.json
[INFO ] 2017-05-30 15:44:42,865 ./wsems: Creating the WsEms proxy.
[TRACE] 2017-05-30 15:44:42,865 wsEmsProxy::wsEmsProxy: Constructor called
[INFO ] 2017-05-30 15:44:42,865 ./wsems: Starting HTTP Server.
[TRACE] 2017-05-30 15:44:42,866 jsonConfigurator::getInteger: Key = port, Parent = h ttp_server
[TRACE] 2017-05-30 15:44:42,866 jsonConfigurator::getString: Key = host, Parent = ht tp_server
[TRACE] 2017-05-30 15:44:42,866 jsonConfigurator::getBoolean: Key = ssl, Parent = ht tp_server
[TRACE] 2017-05-30 15:44:42,866 jsonConfigurator::getValueByType: Key ssl not found
[TRACE] 2017-05-30 15:44:42,867 jsonConfigurator::getString: Key = certificate, Pare nt = http_server
[TRACE] 2017-05-30 15:44:42,867 jsonConfigurator::getValueByType: Key certificate no t found
[TRACE] 2017-05-30 15:44:42,867 jsonConfigurator::getBoolean: Key = authenticate, Pa rent = http_server
192.168.20.37:8443-->[TRACE] 2017-05-30 15:44:42,867 jsonConfigurator::getValueByTyp e: Key authenticate not found
[TRACE] 2017-05-30 15:44:42,868 jsonConfigurator::getInteger: Key = content_read_tim eout, Parent = http_server
[TRACE] 2017-05-30 15:44:42,868 jsonConfigurator::getValueByType: Key content_read_t imeout not found
[INFO ] 2017-05-30 15:44:42,869 ./wsems: Initializing the ThingWorx REST interface.
[TRACE] 2017-05-30 15:44:42,869 wsEmsProxy::initialize: Method entered
[FORCE] 2017-05-30 15:44:42,870 httpServer: Method entered
[TRACE] 2017-05-30 15:44:42,870 jsonConfigurator::getString: Key = level, Parent = l ogger
[TRACE] 2017-05-30 15:44:42,870 jsonConfigurator::getBoolean: Key = verbose, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,871 jsonConfigurator::getString: Key = encryption, Paren t = ws_connection
[TRACE] 2017-05-30 15:44:42,871 jsonConfigurator::getString: Key = user, Parent =
[TRACE] 2017-05-30 15:44:42,871 jsonConfigurator::getValueByType: Key user not found
[TRACE] 2017-05-30 15:44:42,871 jsonConfigurator::getString: Key = password, Parent =
[TRACE] 2017-05-30 15:44:42,871 jsonConfigurator::getValueByType: Key password not f ound
[TRACE] 2017-05-30 15:44:42,872 jsonConfigurator::getString: Key = appkey, Parent =
[TRACE] 2017-05-30 15:44:42,872 jsonConfigurator::getString: Key = resource, Parent =
[TRACE] 2017-05-30 15:44:42,872 jsonConfigurator::getValueByType: Key resource not f ound
[TRACE] 2017-05-30 15:44:42,872 jsonConfigurator::getInteger: Key = port, Parent = p roxy
[TRACE] 2017-05-30 15:44:42,872 jsonConfigurator::getValueByType: Parent proxy not f ound
[TRACE] 2017-05-30 15:44:42,873 jsonConfigurator::getString: Key = host, Parent = pr oxy
[TRACE] 2017-05-30 15:44:42,873 jsonConfigurator::getValueByType: Parent proxy not f ound
[TRACE] 2017-05-30 15:44:42,873 jsonConfigurator::getString: Key = user, Parent = pr oxy
[TRACE] 2017-05-30 15:44:42,873 jsonConfigurator::getString: Key = password, Parent = proxy
[TRACE] 2017-05-30 15:44:42,874 jsonConfigurator::getValueByType: Parent proxy not f ound
[TRACE] 2017-05-30 15:44:42,874 jsonConfigurator::getUnsignedInteger: Key = socket_r ead_timeout, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,874 jsonConfigurator::getValueByType: Key socket_read_ti meout not found
[TRACE] 2017-05-30 15:44:42,874 jsonConfigurator::getUnsignedInteger: Server socket error: Address already in use [127.0.0.1:9080]
[ERROR] 2017-05-30 15:44:42,874 httpserver: Server socket error: Address already in use [127.0.0.1:9080]
[TRACE] 2017-05-30 15:44:42,875 jsonConfigurator::getValueByType:
[ERROR] 2017-05-30 15:44:42,875 httpServer:
[TRACE] 2017-05-30 15:44:42,875 jsonConfigurator::getUnsignedInteger: Key = ssl_read _timeout, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,875 jsonConfigurator::getValueByType: Key ssl_read_timeo ut not found
[TRACE] 2017-05-30 15:44:42,875 jsonConfigurator::getUnsignedInteger: Key = msg_time out, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,876 jsonConfigurator::getUnsignedInteger: Key = ping_rat e, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,876 jsonConfigurator::getValueByType: Key ping_rate not found
[TRACE] 2017-05-30 15:44:42,876 jsonConfigurator::getUnsignedInteger: Key = pingpong _timeout, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,876 jsonConfigurator::getValueByType: Key pingpong_timeo ut not found
[TRACE] 2017-05-30 15:44:42,876 jsonConfigurator::getUnsignedInteger: Key = max_thre ads, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,876 jsonConfigurator::getValueByType: Key max_threads no t found
[TRACE] 2017-05-30 15:44:42,876 jsonConfigurator::getUnsignedInteger: Key = max_msg_ size, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,877 jsonConfigurator::getValueByType: Key max_msg_size n ot found
[TRACE] 2017-05-30 15:44:42,877 jsonConfigurator::getUnsignedInteger: Key = max_mess ages, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,877 jsonConfigurator::getValueByType: Key max_messages n ot found
[TRACE] 2017-05-30 15:44:42,877 jsonConfigurator::getBoolean: Key = verbose, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,877 jsonConfigurator::getBoolean: Key = connect_on_deman d, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,877 jsonConfigurator::getValueByType: Key connect_on_dem and not found
[TRACE] 2017-05-30 15:44:42,877 jsonConfigurator::getUnsignedInteger: Key = max_conn ect_delay, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,877 jsonConfigurator::getValueByType: Key max_connect_de lay not found
[TRACE] 2017-05-30 15:44:42,878 jsonConfigurator::getUnsignedInteger: Key = connect_ period, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,878 jsonConfigurator::getValueByType: Key connect_period not found
[TRACE] 2017-05-30 15:44:42,878 jsonConfigurator::getUnsignedInteger: Key = duty_cyc le, Parent = ws_connection
[ERROR] 2017-05-30 15:44:42,878 httpserver: Server socket error: Address already in use [127.0.0.1:9081]
[TRACE] 2017-05-30 15:44:42,878 jsonConfigurator::getValueByType: Server socket erro r: Address already in use [127.0.0.1:9081]
[ERROR] 2017-05-30 15:44:42,878 httpServer: unable to bind http server to port=9081, trying next port.
[TRACE] 2017-05-30 15:44:42,878 jsonConfigurator::getUnsignedInteger: Key = message_ idle_time, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,878 jsonConfigurator::getValueByType: Key message_idle_t ime not found
[TRACE] 2017-05-30 15:44:42,878 jsonConfigurator::getUnsignedInteger: Key = connect_ timeout, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,878 jsonConfigurator::getValueByType: Key connect_timeou t not found
[TRACE] 2017-05-30 15:44:42,878 jsonConfigurator::getUnsignedInteger: Key = connect_ retry_interval, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,878 jsonConfigurator::getValueByType: Key connect_retry_ interval not found
[TRACE] 2017-05-30 15:44:42,879 jsonConfigurator::getInteger: Key = connect_retries, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,879 jsonConfigurator::getValueByType: Key connect_retrie s not found
[TRACE] 2017-05-30 15:44:42,879 jsonConfigurator::getBoolean: Key = enabled, Parent = offline_msg_store
[TRACE] 2017-05-30 15:44:42,879 jsonConfigurator::getValueByType: Parent offline_msg _store not found
[TRACE] 2017-05-30 15:44:42,880 jsonConfigurator::getString: Key = directory, Parent = offline_msg_store
[TRACE] 2017-05-30 15:44:42,880 jsonConfigurator::getValueByType: Parent offline_msg _store not found
[TRACE] 2017-05-30 15:44:42,880 jsonConfigurator::getUnsignedInteger: Key = max_size , Parent = offline_msg_store
[TRACE] 2017-05-30 15:44:42,880 jsonConfigurator::getValueByType: http server bound to port=9082.
[DEBUG] 2017-05-30 15:44:42,880 httpServer: http server bound to port=9082.
[TRACE] 2017-05-30 15:44:42,880 jsonConfigurator::getUnsignedInteger: Key = message_ chunk_size, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,880 jsonConfigurator::getValueByType: Key message_chunk_ size not found
[DEBUG] 2017-05-30 15:44:42,881 SDK: twWs_Create: Initializing Websocket Client for 192.168.20.37:8443//Thingworx/WS
[DEBUG] 2017-05-30 15:44:42,881 SDK: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2017-05-30 15:44:42,881 SDK: twApi_Initialize: Websocket Established after 0 tries
[DEBUG] 2017-05-30 15:44:42,881 SDK: subscribedPropsMgr_Initialize: Initializing sub scribed properties manager
[TRACE] 2017-05-30 15:44:42,881 jsonConfigurator::getBoolean: Key = validate, Parent = certificates
[TRACE] 2017-05-30 15:44:42,881 jsonConfigurator::getBoolean: Key = deny_self_signed , Parent = certificates
[TRACE] 2017-05-30 15:44:42,882 jsonConfigurator::getValueByType: Key deny_self_sign ed not found
[TRACE] 2017-05-30 15:44:42,882 jsonConfigurator::getBoolean: Key = allow_self_signe d, Parent = certificates
[TRACE] 2017-05-30 15:44:42,882 jsonConfigurator::getString: Key = client_cert, Pare nt = certificates
[TRACE] 2017-05-30 15:44:42,882 jsonConfigurator::getValueByType: Key client_cert no t found
[TRACE] 2017-05-30 15:44:42,882 jsonConfigurator::getString: Key = key_file, Parent = certificates
[TRACE] 2017-05-30 15:44:42,882 jsonConfigurator::getValueByType: Key key_file not f ound
[TRACE] 2017-05-30 15:44:42,883 jsonConfigurator::getString: Key = key_passphrase, P arent = certificates
[TRACE] 2017-05-30 15:44:42,883 jsonConfigurator::getValueByType: Key key_passphrase not found
[DEBUG] 2017-05-30 15:44:42,883 jsonConfigurator::getJsonEntity: Key cert_chain not found
[DEBUG] 2017-05-30 15:44:42,883 jsonConfigurator::getJsonEntity: Key validation_crit eria not found
[TRACE] 2017-05-30 15:44:42,883 jsonConfigurator::getString: Key = staging_dir, Pare nt = file
[TRACE] 2017-05-30 15:44:42,884 jsonConfigurator::getValueByType: Parent file not fo und
[TRACE] 2017-05-30 15:44:42,884 jsonConfigurator::getUnsignedInteger: Key = buffer_s ize, Parent = file
[TRACE] 2017-05-30 15:44:42,884 jsonConfigurator::getDouble: Key = max_file_size, Pa rent = file
[DEBUG] 2017-05-30 15:44:42,884 jsonConfigurator::getJsonEntity: Parent file not fou nd
[TRACE] 2017-05-30 15:44:42,885 SDK: twFileManager_AddVirtualDir: Adding __staging__ to vdir list
[TRACE] 2017-05-30 15:44:42,885 WsEmsProxy::bindThing: Adding Thing RedPi to binding list
[DEBUG] 2017-05-30 15:44:42,885 jsonConfigurator::getJsonEntity: Parent file not fou nd
[INFO ] 2017-05-30 15:44:42,886 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2017-05-30 15:44:42,886 ./wsems: Starting the connection.
[TRACE] 2017-05-30 15:44:42,886 jsonConfigurator::getInteger: Key = connect_retry_in terval, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,886 jsonConfigurator::getValueByType: Key connect_retry_ interval not found
[TRACE] 2017-05-30 15:44:42,886 jsonConfigurator::getInteger: Key = max_connect_dela y, Parent = ws_connection
[TRACE] 2017-05-30 15:44:42,886 jsonConfigurator::getValueByType: Key max_connect_de lay not found
[TRACE] 2017-05-30 15:44:42,887 SDK: twApi_Connect: Delaying 0 milliseconds before c onnecting
[DEBUG] 2017-05-30 15:44:42,887 SDK: twTlsClient_Reconnect: Re-establishing SSL cont ext
[DEBUG] 2017-05-30 15:44:42,887 SDK: twTlsClient_Connect: Connecting to server
[TRACE] 2017-05-30 15:44:42,887 SDK: twWs_Connect: Connected to 192.168.20.37:8443
[TRACE] 2017-05-30 15:44:42,887 SDK: twWs_Connect: Sent request:
GET /Thingworx/WS HTTP/1.1
User-Agent: ThingWorx C SDK
Upgrade: websocket
Connection: Upgrade
Host: 192.168.20.37
Sec-WebSocket-Version: 13
Sec-WebSocket-Key: K2wSDrgRu5z6f1o/qirv4g==
Max-Frame-Size: 8192
appKey: f109ecb5-9e2b-4215-8d3f-6479d5d6b9c1
[ERROR] 2017-05-30 15:44:52,869 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 15:44:52,869 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 15:44:52,870 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-05-30 15:44:57,871 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 15:44:57,872 SDK: twTlsClient_Connect: Connecting to server
[TRACE] 2017-05-30 15:44:57,873 SDK: twWs_Connect: Connected to 192.168.20.37:8443
[TRACE] 2017-05-30 15:44:57,873 SDK: twWs_Connect: Sent request:
Upgrade: websocket
Connection: Upgrade
Host: 192.168.20.37
Sec-WebSocket-Key: Vsg3bgTpTfPat+g++S1gWA==
[ERROR] 2017-05-30 15:45:07,872 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 15:45:07,872 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 15:45:07,873 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-05-30 15:45:12,873 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 15:45:12,874 SDK: twTlsClient_Connect: Connecting to server
[TRACE] 2017-05-30 15:45:12,875 SDK: twWs_Connect: Connected to 192.168.20.37:8443
[TRACE] 2017-05-30 15:45:12,875 SDK: twWs_Connect: Sent request:
Upgrade: websocket
Connection: Upgrade
Host: 192.168.20.37
Sec-WebSocket-Key: 4c60G//iroTJJ/xUrbO4cQ==
[ERROR] 2017-05-30 15:45:22,875 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 15:45:22,876 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 15:45:22,876 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-05-30 15:45:27,877 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 15:45:27,877 SDK: twTlsClient_Connect: Connecting to server
[TRACE] 2017-05-30 15:45:27,878 SDK: twWs_Connect: Connected to 192.168.20.37:8443
[TRACE] 2017-05-30 15:45:27,878 SDK: twWs_Connect: Sent request:
Upgrade: websocket
Connection: Upgrade
Host: 192.168.20.37
Sec-WebSocket-Key: b3FYTKV+0GgloJgR2ykkHQ==
[ERROR] 2017-05-30 15:45:37,878 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 15:45:37,878 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 15:45:37,879 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-05-30 15:45:42,882 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 15:45:42,883 SDK: twTlsClient_Connect: Connecting to server
[TRACE] 2017-05-30 15:45:42,885 SDK: twWs_Connect: Connected to 192.168.20.37:8443
[TRACE] 2017-05-30 15:45:42,885 SDK: twWs_Connect: Sent request:
Upgrade: websocket
Connection: Upgrade
Host: 192.168.20.37
Sec-WebSocket-Key: TT6oGnLX5utZrbaC9YS7bw==
[WARN ] 2017-05-30 15:45:42,901 Main: Unable to connect to server. Trying .booted config file
[ERROR] 2017-05-30 15:45:52,885 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 15:45:52,886 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 15:45:52,886 SDK: twTlsClient_Connect: Connecting to server
[WARN ] 2017-05-30 15:45:57,887 WsEmsProxy::execute() : Server connection failed. Error Code: 201
[FORCE] 2017-05-30 15:45:57,988 Main: Shutdown signal received. Restarting ....
[TRACE] 2017-05-30 15:45:57,989 wsEmsProxy::~wsEmsProxy: Destructor called
[TRACE] 2017-05-30 15:45:57,989 WsProxy::~WsProxy: Deleting Thing binding list
[TRACE] 2017-05-30 15:45:57,989 SDK: Sending Msg >>>>>>>>>
Message Details:
Version: 1
Method/Code: 0xb (UNBIND)
RequestID: 1
EndpointID:0
SessionID: 0
Multipart: 0
Count: 1
[DEBUG] 2017-05-30 15:45:57,990 SDK: twMessage_Send: Not authenticated yet
[ERROR] 2017-05-30 15:45:57,990 SDK: twMessage_Send: Error sending Message with RequestId 1
[ERROR] 2017-05-30 15:45:57,990 SDK: twApi_UnbindThing: Error creating sending Unbind message
[DEBUG] 2017-05-30 15:45:57,990 SDK: twMessage_Delete: Deleting BIND Message: 1
[INFO ] 2017-05-30 17:06:25,368 ./wsems: Using config file: /home/pi/ems/microserver/etc/config.json
[FORCE] 2017-05-30 17:06:25,368 ./wsems: Starting up ....
[TRACE] 2017-05-30 17:06:25,368 jsonConfigurator::getString: Key = audit_target, Parent = logger
[TRACE] 2017-05-30 17:06:25,368 jsonConfigurator::getValueByType: Key audit_target not found
[TRACE] 2017-05-30 17:06:25,368 jsonConfigurator::getString: Key = publish_directory, Parent = logger
[TRACE] 2017-05-30 17:06:25,369 jsonConfigurator::getValueByType: Key publish_directory not found
[TRACE] 2017-05-30 17:06:25,369 jsonConfigurator::getUnsignedInteger: Key = max_file_storage, Parent = logger
[TRACE] 2017-05-30 17:06:25,369 jsonConfigurator::getValueByType: Key max_file_storage not found
[TRACE] 2017-05-30 17:06:25,369 jsonConfigurator::getString: Key = publish_level, Parent = logger
[TRACE] 2017-05-30 17:06:25,369 jsonConfigurator::getValueByType: Key publish_level not found
[TRACE] 2017-05-30 17:06:25,369 jsonConfigurator::getBoolean: Key = auto_flush, Parent = logger
[TRACE] 2017-05-30 17:06:25,369 jsonConfigurator::getValueByType: Key auto_flush not found
[FORCE] 2017-05-30 17:06:25,369 ./wsems: Initializing EMS ....
[FORCE] 2017-05-30 17:06:25,369 main: Using config file /home/pi/ems/microserver/etc/config.json
[INFO ] 2017-05-30 17:06:25,369 ./wsems: Creating the WsEms proxy.
[TRACE] 2017-05-30 17:06:25,369 wsEmsProxy::wsEmsProxy: Constructor called
[INFO ] 2017-05-30 17:06:25,370 ./wsems: Starting HTTP Server.
[TRACE] 2017-05-30 17:06:25,370 jsonConfigurator::getInteger: Key = port, Parent = http_server
[TRACE] 2017-05-30 17:06:25,370 jsonConfigurator::getString: Key = host, Parent = http_server
[TRACE] 2017-05-30 17:06:25,370 jsonConfigurator::getBoolean: Key = ssl, Parent = http_server
[TRACE] 2017-05-30 17:06:25,370 jsonConfigurator::getValueByType: Key ssl not found
[TRACE] 2017-05-30 17:06:25,370 jsonConfigurator::getString: Key = certificate, Parent = http_server
[TRACE] 2017-05-30 17:06:25,370 jsonConfigurator::getValueByType: Key certificate not found
[TRACE] 2017-05-30 17:06:25,370 jsonConfigurator::getBoolean: Key = authenticate, Parent = http_server
[TRACE] 2017-05-30 17:06:25,370 jsonConfigurator::getValueByType: Key authenticate not found
[TRACE] 2017-05-30 17:06:25,370 jsonConfigurator::getInteger: Key = content_read_timeout, Parent = http_server
[TRACE] 2017-05-30 17:06:25,370 jsonConfigurator::getValueByType: Key content_read_timeout not found
[INFO ] 2017-05-30 17:06:25,371 ./wsems: Initializing the ThingWorx REST interface.
[TRACE] 2017-05-30 17:06:25,371 wsEmsProxy::initialize: Method entered
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getString: Key = level, Parent = logger
[FORCE] 2017-05-30 17:06:25,371 httpServer: starting http server port=9080
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getBoolean: Key = verbose, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getString: Key = encryption, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getString: Key = user, Parent =
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getValueByType: Key user not found
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getString: Key = password, Parent =
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getValueByType: Key password not found
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getString: Key = appkey, Parent =
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getString: Key = resource, Parent =
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getValueByType: Key resource not found
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getInteger: Key = port, Parent = proxy
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getValueByType: Parent proxy not found
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getString: Key = host, Parent = proxy
[TRACE] 2017-05-30 17:06:25,371 jsonConfigurator::getString: Key = user, Parent = proxy
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getString: Key = password, Parent = proxy
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getValueByType: Parent proxy not found
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getUnsignedInteger: Key = socket_read_timeout, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getValueByType: Key socket_read_timeout not found
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getUnsignedInteger: Key = frame_read_timeout, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getValueByType: Key frame_read_timeout not found
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getUnsignedInteger: Key = ssl_read_timeout, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getValueByType: Key ssl_read_timeout not found
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getUnsignedInteger: Key = msg_timeout, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getUnsignedInteger: Key = ping_rate, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getValueByType: Key ping_rate not found
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getUnsignedInteger: Key = pingpong_timeout, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getValueByType: Key pingpong_timeout not found
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getUnsignedInteger: Key = max_threads, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getValueByType: Key max_threads not found
[TRACE] 2017-05-30 17:06:25,372 jsonConfigurator::getUnsignedInteger: Key = max_msg_size, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getValueByType: Key max_msg_size not found
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getUnsignedInteger: Key = max_messages, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getValueByType: Key max_messages not found
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getBoolean: Key = verbose, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getBoolean: Key = connect_on_demand, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getValueByType: Key connect_on_demand not found
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getUnsignedInteger: Key = max_connect_delay, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getValueByType: Key max_connect_delay not found
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getUnsignedInteger: Key = connect_period, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getValueByType: Key connect_period not found
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getUnsignedInteger: Key = duty_cycle, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getValueByType: Key duty_cycle not found
[ERROR] 2017-05-30 17:06:25,373 httpserver: Key = message_idle_time, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getUnsignedInteger: Key = message_idle_time, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getValueByType: Key message_idle_time not found
[ERROR] 2017-05-30 17:06:25,373 httpServer: Key message_idle_time not found
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getUnsignedInteger: Key = connect_timeout, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,373 jsonConfigurator::getValueByType: Key connect_timeout not found
[TRACE] 2017-05-30 17:06:25,374 jsonConfigurator::getUnsignedInteger: Key = connect_retry_interval, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,374 jsonConfigurator::getValueByType: Key connect_retry_interval not found
[TRACE] 2017-05-30 17:06:25,374 jsonConfigurator::getInteger: Key = connect_retries, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,374 jsonConfigurator::getValueByType: Key connect_retries not found
[TRACE] 2017-05-30 17:06:25,374 jsonConfigurator::getBoolean: Key = enabled, Parent = offline_msg_store
[TRACE] 2017-05-30 17:06:25,374 jsonConfigurator::getValueByType: Parent offline_msg_store not found
[TRACE] 2017-05-30 17:06:25,374 jsonConfigurator::getString: Key = directory, Parent = offline_msg_store
[TRACE] 2017-05-30 17:06:25,374 jsonConfigurator::getUnsignedInteger: Key = max_size, Parent = offline_msg_store
[TRACE] 2017-05-30 17:06:25,374 jsonConfigurator::getUnsignedInteger: Key = message_chunk_size, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,374 jsonConfigurator::getValueByType: Key message_chunk_size not found
[ERROR] 2017-05-30 17:06:25,374 httpserver: Server socket error: Address already in use [127.0.0.1:9081]
[ERROR] 2017-05-30 17:06:25,374 httpServer: unable to bind http server to port=9081, trying next port.
[DEBUG] 2017-05-30 17:06:25,374 SDK: twWs_Create: Initializing Websocket Client for 192.168.20.37:8443//Thingworx/WS
[DEBUG] 2017-05-30 17:06:25,374 SDK: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2017-05-30 17:06:25,374 httpServer: http server bound to port=9082.
[DEBUG] 2017-05-30 17:06:25,375 SDK: twApi_Initialize: Websocket Established after 0 tries
[DEBUG] 2017-05-30 17:06:25,375 SDK: subscribedPropsMgr_Initialize: Initializing subscribed properties manager
[TRACE] 2017-05-30 17:06:25,376 jsonConfigurator::getBoolean: Key = validate, Parent = certificates
[TRACE] 2017-05-30 17:06:25,376 jsonConfigurator::getBoolean: Key = deny_self_signed, Parent = certificates
[TRACE] 2017-05-30 17:06:25,376 jsonConfigurator::getValueByType: Key deny_self_signed not found
[TRACE] 2017-05-30 17:06:25,376 jsonConfigurator::getBoolean: Key = allow_self_signed, Parent = certificates
[TRACE] 2017-05-30 17:06:25,376 jsonConfigurator::getString: Key = client_cert, Parent = certificates
[TRACE] 2017-05-30 17:06:25,376 jsonConfigurator::getValueByType: Key client_cert not found
[TRACE] 2017-05-30 17:06:25,376 jsonConfigurator::getString: Key = key_file, Parent = certificates
[TRACE] 2017-05-30 17:06:25,377 jsonConfigurator::getValueByType: Key key_file not found
[TRACE] 2017-05-30 17:06:25,377 jsonConfigurator::getString: Key = key_passphrase, Parent = certificates
[TRACE] 2017-05-30 17:06:25,377 jsonConfigurator::getValueByType: Key key_passphrase not found
[DEBUG] 2017-05-30 17:06:25,377 jsonConfigurator::getJsonEntity: Key cert_chain not found
[DEBUG] 2017-05-30 17:06:25,377 jsonConfigurator::getJsonEntity: Key validation_criteria not found
[TRACE] 2017-05-30 17:06:25,378 jsonConfigurator::getString: Key = staging_dir, Parent = file
[TRACE] 2017-05-30 17:06:25,378 jsonConfigurator::getValueByType: Parent file not found
[TRACE] 2017-05-30 17:06:25,378 jsonConfigurator::getUnsignedInteger: Key = buffer_size, Parent = file
[TRACE] 2017-05-30 17:06:25,378 jsonConfigurator::getDouble: Key = max_file_size, Parent = file
[DEBUG] 2017-05-30 17:06:25,378 jsonConfigurator::getJsonEntity: Parent file not found
[TRACE] 2017-05-30 17:06:25,378 SDK: twFileManager_AddVirtualDir: Adding __staging__ to vdir list
[TRACE] 2017-05-30 17:06:25,379 WsEmsProxy::bindThing: Adding Thing RedPi to binding list
[DEBUG] 2017-05-30 17:06:25,379 jsonConfigurator::getJsonEntity: Parent file not found
[INFO ] 2017-05-30 17:06:25,379 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2017-05-30 17:06:25,380 ./wsems: Starting the connection.
[TRACE] 2017-05-30 17:06:25,380 jsonConfigurator::getInteger: Key = connect_retry_interval, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,380 jsonConfigurator::getValueByType: Key connect_retry_interval not found
[TRACE] 2017-05-30 17:06:25,380 jsonConfigurator::getInteger: Key = max_connect_delay, Parent = ws_connection
[TRACE] 2017-05-30 17:06:25,380 jsonConfigurator::getValueByType: Key max_connect_delay not found
192.168.20.37:8443-->[TRACE] 2017-05-30 17:06:25,381 SDK: twApi_Connect: Delaying 0 milliseconds before connecting
[DEBUG] 2017-05-30 17:06:25,381 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 17:06:25,381 SDK: twTlsClient_Connect: Connecting to server
[TRACE] 2017-05-30 17:06:25,383 SDK: twWs_Connect: Connected to 192.168.20.37:8443
[TRACE] 2017-05-30 17:06:25,383 SDK: twWs_Connect: Sent request:
Upgrade: websocket
Connection: Upgrade
Host: 192.168.20.37
Sec-WebSocket-Key: dOMngeyYOntcrChQIIw6Cg==
[ERROR] 2017-05-30 17:06:35,382 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 17:06:35,382 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 17:06:35,383 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-05-30 17:06:40,384 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 17:06:40,384 SDK: twTlsClient_Connect: Connecting to server
[TRACE] 2017-05-30 17:06:40,385 SDK: twWs_Connect: Connected to 192.168.20.37:8443
[TRACE] 2017-05-30 17:06:40,385 SDK: twWs_Connect: Sent request:
Upgrade: websocket
Connection: Upgrade
Host: 192.168.20.37
Sec-WebSocket-Key: mNpsKXV+60P1BROktWYy6Q==
[ERROR] 2017-05-30 17:06:50,385 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 17:06:50,385 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 17:06:50,386 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-05-30 17:06:55,387 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 17:06:55,388 SDK: twTlsClient_Connect: Connecting to server
[TRACE] 2017-05-30 17:06:55,389 SDK: twWs_Connect: Connected to 192.168.20.37:8443
[TRACE] 2017-05-30 17:06:55,389 SDK: twWs_Connect: Sent request:
Upgrade: websocket
Connection: Upgrade
Host: 192.168.20.37
Sec-WebSocket-Key: iDBoFibySUAryVIP/KsWzA==
[ERROR] 2017-05-30 17:07:05,389 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 17:07:05,390 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 17:07:05,390 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-05-30 17:07:10,392 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 17:07:10,393 SDK: twTlsClient_Connect: Connecting to server
[TRACE] 2017-05-30 17:07:10,394 SDK: twWs_Connect: Connected to 192.168.20.37:8443
[TRACE] 2017-05-30 17:07:10,394 SDK: twWs_Connect: Sent request:
Upgrade: websocket
Connection: Upgrade
Host: 192.168.20.37
Sec-WebSocket-Key: PMnGd3t3hmREYmGiLDsI+g==
[ERROR] 2017-05-30 17:07:20,394 SDK: twWs_Connect: Error trying to connect
[DEBUG] 2017-05-30 17:07:20,395 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-05-30 17:07:20,395 SDK: twTlsClient_Connect: Connecting to server
[WARN ] 2017-05-30 17:07:25,389 Main: Unable to connect to server. Trying .booted config file
[WARN ] 2017-05-30 17:07:25,397 WsEmsProxy::execute() : Server connection failed. Error Code: 201
[FORCE] 2017-05-30 17:07:25,500 Main: Shutdown signal received. Restarting ....
[TRACE] 2017-05-30 17:07:25,500 wsEmsProxy::~wsEmsProxy: Destructor called
[TRACE] 2017-05-30 17:07:25,500 WsProxy::~WsProxy: Deleting Thing binding list
[TRACE] 2017-05-30 17:07:25,500 SDK: Sending Msg >>>>>>>>>
Message Details:
Version: 1
RequestID: 1
EndpointID:0
SessionID: 0
Multipart: 0
Count: 1
[DEBUG] 2017-05-30 17:07:25,501 SDK: twMessage_Send: Not authenticated yet
[ERROR] 2017-05-30 17:07:25,501 SDK: twMessage_Send: Error sending Message with RequestId 1
[ERROR] 2017-05-30 17:07:25,501 SDK: twApi_UnbindThing: Error creating sending Unbind message
[DEBUG] 2017-05-30 17:07:25,501 SDK: twMessage_Delete: Deleting BIND Message: 1
Hello Bill,
This my config.json:
"ws_servers": [{
"host": "192.XXX.XX.XX",
"port": 443
"http_server": {
"host": "192.XXX.XX.XX", #Static IP address of Raspberry Pi
"port": 8080
"logger": {
"level": "DEBUG"
"auto_bind": [{
"name": "PiThing2",
"gateway": false
"certificates": {
"validate": false,
"ws_connection": {
"verbose": true,
"msg_timeout": 1000
Bill, I figured out the issue with help from another discussion. I did not set my ws connection correctly:
"ws_connection": {
"encryption": "none", <-- should be "encryption": "SSL",
"verbose": true,
"msg_timeout": 1000
