It seems Thingworx loads properly until it hits this point in the log:
2017-08-14 15:39:27.954+0200 [L: INFO] [O: c.t.p.c.LicenseMonitor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting [LicenseMonitor].
2017-08-14 15:39:28.347+0200 [L: INFO] [O: c.t.p.p.PersistenceProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Connection ThingworxPersistenceProvider, type H2PersistenceProviderPackage stopped
2017-08-14 15:39:28.361+0200 [L: WARN] [O: c.t.p.c.LicenseMonitor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Stopping [LicenseMonitor].
2017-08-14 15:39:28.366+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WebApp stopping:
2017-08-14 15:39:28.366+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-08-14 15:39:28.367+0200 [L: ERROR] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Error Attempting To Stop Scheduler: null
2017-08-14 15:39:28.367+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-08-14 15:39:28.367+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Stopping Platform Subsystems
From here everything just stops.
What can be the issue??
This is a new installation of Twx 8 on Ubuntu (H2).
License file is loaded in the ThingworxPlatform folder.
Hi Hein Van Loggerenberg,
Open /etc/systemd/system/tomcat8.service file in a text editor and look for the line Djava.library.path=${CATALINA_BASE}/webapps/Thingworx/WEB-INF/extensions
Now exit from the file and check the value of ${CATALINA_BASE}
To check the value, enter the following command:
echo $CATALINA_BASE
verify this output is same as the tomcat installation path.
For example, it should have the value: "/usr/share/tomcat8.5/8.5.13/".
If it doesn’t have that value, then set the tomcat installation path with the below command:
export CATALINA_BASE=/usr/share/tomcat8.5/8.5.13/
verify if it now has that value: echo $CATALINA_BASE
Restart Tomcat and launch ThingWorx composer.
Thanks for your quick response.
I have added the CATALINA_BASE to the environment file and it is functional now.
But I still get the same issue
I have added the logs of the catalina.out and ApplicationLog.log
Further I am unsure of the tomcat8.5.service file:
1. What should the persmissions and owner be ? Currently it is:
-rw-r--r-- 1 root root 1064 Aug 15 08:29 /etc/systemd/system/tomcat8.5.service
2. The contents of the file was copied from the pdf installation file. There were a lot of line feeds that should not be there
I "cleaned" the text to the best of my ability, but I am not sure if it is correct.
See below the file contents:
[Unit]
Description=Apache Tomcat Web Application Container
After=network.target
[Service]
Type=forking
PIDFile=/var/run/tomcat.pid
Environment=CATALINA_PID=/var/run/tomcat.pid
Environment=JAVA_HOME=/usr/lib/jvm/jdk1.8.0_92
Environment=CATALINA_HOME=/usr/share/tomcat8.5/8.5.13
Environment=CATALINA_BASE=/usr/share/tomcat8.5/8.5.13
Environment=CATALINA_OPTS=ExecStart=/usr/share/tomcat8.5/8.5.13/bin/jsvc \
-Dcatalina.home=${CATALINA_HOME} \
-Dcatalina.base=${CATALINA_BASE} \
-Djava.awt.headless=true -Djava.net.preferIPv4Stack=true -Dserver -Dd64 -XX:+UseNUMA \
-XX:+UseConcMarkSweepGC -Dfile.encoding=UTF-8 \
-Djava.library.path=${CATALINA_BASE}/webapps/Thingworx/WEB-INF/extensions \
-cp ${CATALINA_HOME}/bin/commons-daemon.jar:${CATALINA_HOME}/bin/bootstrap.jar:${CATALINA_HOME}/bin/tomcat-juli.jar \
-user tomcat8.5 \
-java-home ${JAVA_HOME} \
-pidfile /var/run/tomcat.pid \
-errfile
${CATALINA_HOME}/logs/catalina.out \
-outfile
$CATALINA_OPTS \
org.apache.catalina.startup.Bootstrap
[Install]
WantedBy=multi-user.target
catalina.out
15-Aug-2017 08:30:18.927 INFO [main] org.apache.catalina.core.StandardServer.await A valid shutdown command was received via the shutdown port. Stopping the Server instance.
15-Aug-2017 08:30:18.927 INFO [main] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8080"]
15-Aug-2017 08:30:18.979 INFO [main] org.apache.catalina.core.StandardService.stopInternal Stopping service Catalina
15-Aug-2017 08:30:18.994 INFO [main] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8080"]
15-Aug-2017 08:30:18.995 INFO [main] org.apache.coyote.AbstractProtocol.destroy Destroying ProtocolHandler ["http-nio-8080"]
15-Aug-2017 08:30:23.059 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.5.13
15-Aug-2017 08:30:23.060 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Mar 27 2017 14:25:04 UTC
15-Aug-2017 08:30:23.060 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.5.13.0
15-Aug-2017 08:30:23.060 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Linux
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 4.4.0-91-generic
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /usr/lib/jvm/jdk1.8.0_92/jre
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_92-b14
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /usr/share/tomcat8.5/8.5.13
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /usr/share/tomcat8.5/8.5.13
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/usr/share/tomcat8.5/8.5.13//conf/logging.properties
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/usr/share/tomcat8.5/8.5.13/
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/usr/share/tomcat8.5/8.5.13
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/usr/share/tomcat8.5/8.5.13//temp
15-Aug-2017 08:30:23.061 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
15-Aug-2017 08:30:23.131 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
15-Aug-2017 08:30:23.140 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
15-Aug-2017 08:30:23.141 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 270 ms
15-Aug-2017 08:30:23.154 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
15-Aug-2017 08:30:23.155 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.13
15-Aug-2017 08:30:23.168 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive /usr/share/tomcat8.5/8.5.13/webapps/Thingworx.war
15-Aug-2017 08:30:25.809 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
System property [org.owasp.esapi.opsteam] is not set
System property [org.owasp.esapi.devteam] is not set
Attempting to load ESAPI.properties via file I/O.
Attempting to load ESAPI.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: /ThingworxStorage/esapi/ESAPI.properties
Loaded 'ESAPI.properties' properties file
Attempting to load validation.properties via file I/O.
Attempting to load validation.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: /ThingworxStorage/esapi/validation.properties
Loaded 'validation.properties' properties file
No protocol specified
15-Aug-2017 08:30:29.438 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
15-Aug-2017 08:30:29.441 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
15-Aug-2017 08:30:29.454 WARNING [localhost-startStop-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [Thingworx] registered the JDBC driver [org.h2.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
15-Aug-2017 08:30:29.459 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive /usr/share/tomcat8.5/8.5.13/webapps/Thingworx.war has finished in 6,290 ms
15-Aug-2017 08:30:29.459 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /usr/share/tomcat8.5/8.5.13/webapps/ROOT
15-Aug-2017 08:30:29.472 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /usr/share/tomcat8.5/8.5.13/webapps/ROOT has finished in 13 ms
15-Aug-2017 08:30:29.472 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /usr/share/tomcat8.5/8.5.13/webapps/host-manager
15-Aug-2017 08:30:29.483 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /usr/share/tomcat8.5/8.5.13/webapps/host-manager has finished in 11 ms
15-Aug-2017 08:30:29.483 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /usr/share/tomcat8.5/8.5.13/webapps/examples
15-Aug-2017 08:30:29.546 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /usr/share/tomcat8.5/8.5.13/webapps/examples has finished in 63 ms
15-Aug-2017 08:30:29.546 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /usr/share/tomcat8.5/8.5.13/webapps/docs
15-Aug-2017 08:30:29.552 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /usr/share/tomcat8.5/8.5.13/webapps/docs has finished in 6 ms
15-Aug-2017 08:30:29.552 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /usr/share/tomcat8.5/8.5.13/webapps/manager
15-Aug-2017 08:30:29.560 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /usr/share/tomcat8.5/8.5.13/webapps/manager has finished in 8 ms
15-Aug-2017 08:30:29.563 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
15-Aug-2017 08:30:29.568 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 6426 ms
ApplicationLog.log
2017-08-15 08:30:26.018+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-08-15 08:30:26.019+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx Version Information
2017-08-15 08:30:26.019+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-08-15 08:30:26.019+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] majorVersion = 8
2017-08-15 08:30:26.019+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] minorVersion = 0
2017-08-15 08:30:26.019+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] revision = 1
2017-08-15 08:30:26.019+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] build = b39
2017-08-15 08:30:26.019+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] schemaVersion = 1000
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx System Environment Settings
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS: Linux
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS arch: amd64
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS version: 4.4.0-91-generic
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Total Processors: 8
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default encoding: UTF-8
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA vendor: Oracle Corporation
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA version: 1.8.0_92
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA install location: /usr/lib/jvm/jdk1.8.0_92/jre
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JVM Max Memory: 3536 (MB)
2017-08-15 08:30:26.020+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WebApp starting...
2017-08-15 08:30:26.337+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] HA mode not enabled. Initializing and starting in standalone mode.
2017-08-15 08:30:26.337+0200 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default Persistence Provider Name = ThingworxPersistenceProvider
2017-08-15 08:30:26.337+0200 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default Persistence Provider Package Name = H2PersistenceProviderPackage
2017-08-15 08:30:27.005+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Managers...INITIALIZED
2017-08-15 08:30:27.006+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Database initialization started...
2017-08-15 08:30:27.565+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] System ownership locking started...
2017-08-15 08:30:27.566+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] System ownership locking complete
2017-08-15 08:30:28.150+0200 [L: WARN] [O: c.t.p.Project] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The project name of a project cannot be changed. It must be set to itself
2017-08-15 08:30:28.856+0200 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing entities
2017-08-15 08:30:28.875+0200 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing ModelTags
2017-08-15 08:30:28.875+0200 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing DataTags
2017-08-15 08:30:28.876+0200 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Groups
2017-08-15 08:30:28.877+0200 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Organizations
2017-08-15 08:30:28.941+0200 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Logs
2017-08-15 08:30:28.970+0200 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing DataShapes
2017-08-15 08:30:28.972+0200 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing ThingShapes
2017-08-15 08:30:28.974+0200 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing ThingPackages
2017-08-15 08:30:29.072+0200 [L: INFO] [O: c.t.p.c.LicenseMonitor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting [LicenseMonitor].
2017-08-15 08:30:29.428+0200 [L: INFO] [O: c.t.p.p.PersistenceProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Connection ThingworxPersistenceProvider, type H2PersistenceProviderPackage stopped
2017-08-15 08:30:29.443+0200 [L: WARN] [O: c.t.p.c.LicenseMonitor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Stopping [LicenseMonitor].
2017-08-15 08:30:29.449+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WebApp stopping:
2017-08-15 08:30:29.449+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-08-15 08:30:29.450+0200 [L: ERROR] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Error Attempting To Stop Scheduler: null
2017-08-15 08:30:29.450+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-08-15 08:30:29.450+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Stopping Platform Subsystems
2017-08-15 08:30:29.450+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem {} is not running
2017-08-15 08:30:29.450+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thingworx Server Application...OFF
2017-08-15 08:30:29.451+0200 [L: ERROR] [O: c.t.s.m.BaseManager] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable To Cleanup Entity ThingworxPersistenceProvider in PersistenceProviders
2017-08-15 08:30:29.451+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thingworx Server Application...Cleaned up
2017-08-15 08:30:29.451+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WebApp OFF [server = Apache Tomcat/8.5.13]
2017-08-15 08:30:29.451+0200 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Error getting ApplicationContext: {}null
