Connectivity With Hosted Server
ShanuGarg
8-Gravel
Hello everyone,
Can anyone Suggest in eclipse program
config.setUri("wss://https://PP-1811230905UC.devportal.ptc.io/Thingworx:80/Thingworx/WS");
Is It a Correct way to use ?
and when I run this program, it shows a port out of range exception.
6 REPLIES 6
dupatel
(To:ShanuGarg)
@ShanuGarg You should not enter https in the URL. Try below and make sure port entered is correct
"wss://PP-1811230905UC.devportal.ptc.io/Thingworx:80/Thingworx/WS"
-Durgesh
I tried with Https and http both but It didn't work
dupatel
(To:ShanuGarg)
@ShanuGarg Which port you are using with https ? The port will be different for http and https.
-Durgesh
Ya I know that I tried so may like 80, 443 etc
jwyatt
(To:ShanuGarg)
Greetings,
It appears that your hosted DevPortal trial expired on December 23rd. You first posted this issue on the 13th, though. So, unfortunately, your trial expired before we could get back to you.
My *guess* is that it was port blocking. The hosted servers are fairly locked down. The guides on the DevPortal are careful to give instructions that we know will work. It appears that you were trying to do something with Eclipse other than something that we'd instruct in a guide. Because of our security, that may not be viable. But, still, sorry for the delay in response.
I may have a solution, however. Our downloadable trials run for 120-days, and you run them on your own system. As such, they're not locked down like the hosted servers are.
You may download them here: https://developer.thingworx.com/en/resources/downloads
If I'm in error and you were trying to follow the instructions in one of our guides (such as the Eclipse "Create an Extension" guide here: https://developer.thingworx.com/en/resources/guides/eclipse-plugin-thingworx-extension-development-tutorial), please let us know so that we can correct our instructions.
Thank you,
Jason
slangley
(To:jwyatt)
Hi @ShanuGarg.
If the response provided by @jwyatt answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
