Logging out and redirecting to an URL
  • December 12, 2018
  • 2 replies
  • 3587 views
My goal is simply to log the user out from ThingWorx and redirect to a custom URL. However I've ran in to several issues trying to achieve this.
Official "Logout button" widget:
The main issue is that there is no possibility to redirect to an URL, only to a mashup so this seems like a dead-end.
Customized "Logout button" widget by PTC Labs:
This widget logs out and redirects correctly as long as the url is external. When trying to redirect to a "/Thingworx/*" URL on the same domain the user is never logged out.
Manual solution with REST call:
When making a REST call to "/Thingworx/Server/*/Services/" using the ThingworxInvoker the user is successfully logged out, but a basic authentication prompt is immediately displayed for the user.
Is there a widget, or any way, to simply log the user out and redirect to a specified URL without a basic authentication prompt displaying in Thingworx?
Thanks in advance.
Support
December 12, 2018
Hi @CMabr.
Please take a look at the following articles for potential solutions to your problem:
Logout Button functionality with redirect link/URL does not work in ThingWorx
How to Logout a user from a Mashup in ThingWorx
Regard.
--Sharon
If my response has answered your question, please mark it as the Accepted Solution, for the benefit of others who may have the same question.
CMabr1-VisitorAuthor
Thanks for the reply. When using REST to invoke Logout or TerminateUserSessions I get a 200 OK response, but the session is still active and the user is not logged out.
If I invoke the same service(s) with the ThingworxInvoker it ends the session correctly, but a basic authentication form is immediately shown afterwards which I'm trying to avoid.
20-Turquoise
December 31, 2018
On your third REST method, have you tried: http://<server>/Thingworx/Server/*/Services/Logout?method=post&_redirectURL=<URL>
(set the url, for example, to the form login page)
Otherwise, you may need to look into a custom authenticator. The topic has been discussed here before, please take a look to see if any help:
https://community.ptc.com/t5/ThingWorx-Developers/Redirect-login-to-FormLogin/m-p/506704
Support
January 7, 2019
Hi @CMabr.
If one of the previous responses helped you to find a solution to your problem, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
